Problem with Outlook truncating images
callumtiller
I'm making an eblast, but everytime I send a preview to myself on Outlook there's one image that always gets split in half. y u no work.jpg
The coding for each table is exactly the same, as you can see the seventh deal there underneath is absolutely fine.
Here's my coding for the deals table. I'm doing an apprenticeship at the moment, so I'm a bit sloppy with HTML as I've only just started to learn it! table code.jpg
Has anyone had this problem before? I know of the page break rendering bug that Outlook is prone to, but I'm confused as to why it's not then going across the wrapper table as well.
Any help would be appreciated!
Can you post a text file with the page source (or a link to a text file) so I can test it here?
What size are the image (in pixels)?
In one quickie test: bad news: I can't repro. The message looks perfect in Outlook (2013) and gmail & outlook.com when sent from Outlook. I'll retest using other versions and send it from my bulk mail software.
Yeah it's a strange one, thanks a lot for your help.
My guess is that it's a rendering issue - if the affected image falls on "the fold" it doesn't render correctly on the screen. But i'll check it in other versions to see if i can repro.
Problem has been solved. My higher up had a look and suggested adding another table inside the first one, and lo and behold it worked!
I still can't see how it wouldn't work in the first place, thanks a lot for your help though.
Marc2019 Outlook 2016 Font Problem Using Outlook 4
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
K Outlook(hotmail)Yahoo problem Using Outlook 6
N Outlook 2013 and Surface RT synchronisation problem Using Outlook 3
F Outlook group by conversation problem Using Outlook 1
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
C Outlook problem Using Outlook 9
P problem with set up group by conversation in outlook 2010 Using Outlook 3
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
M Outlook synchronisation problem (Error : 80041003) Using Outlook 0
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
A Problem sync group goole calendar with outlook 2001 Using Outlook 0
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
B Outlook network password problem. Using Outlook 0
L Problem with Outlook 2007 with windows 7 Using Outlook 0
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
V New problem, .oft extentions in Outlook 2013 Using Outlook 5
W Outlook Stationary Font Formating Problem Using Outlook 7
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
J My Headset problem when Dialing Out from Outlook Contacts Using Outlook 1
W New Problem using Outlook over network Using Outlook 1
H Downloading Outlook 2010 from Volume Licensing Centre problem Using Outlook 1
M Outlook 2010 Custom Form Problem Using Outlook 1
A i have problem with my outlook 2010 pop account Using Outlook 2
