Uninstall Click and Run
AHLong
Outlook 2013 32 bit
I need to uninstall the click and run feature from Office 2013 Home and Business, as I need to use a software that is compatible with this feature.
The only version of Office available to most users is click to run and most software should work with it. If your software really won't work with it, then you'll need to use an older version of Office that is supports.
What software is it?
AHLong
Outlook 2013 32 bit
It is called PC Law. Version 13.
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
S How to uninstall Outlook 2010 Using Outlook 2
Diane Poremsky How to Uninstall Outlook from an Office Installation Using Outlook 0
R How to Uninstall Outlook 2007 Using Outlook 3
M RE: how do I uninstall business contact manager? BCM (Business Contact Manager) 1
T Calendar Printing Assistant Crashes - Cannot Uninstall Using Outlook 8
S mouse right click options Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
L Add to Right Click Menu Using Outlook 10
T Is the standalone Outlook 2013 click-to-run or msi? Using Outlook 1
B Right click-drag no longer creates hyperlinks Using Outlook 2
A email folders appear empty, at first click Using Outlook 2
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
M right click contact to create an appointment Using Outlook 4
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
F When I click on link in email nothing occurs Using Outlook 7
M Programatically click the Send button. Outlook VBA and Custom Forms 5
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
M auto click hyperlink?! Outlook VBA and Custom Forms 1
M Auto click a hyperlink Outlook VBA and Custom Forms 2
H Program "Click on Ribbon Button" Using VBA Outlook VBA and Custom Forms 1
J Macro to open email (like double click) in Outlook Outlook VBA and Custom Forms 4
M How to provide custom functionality on click of "New"? Outlook VBA and Custom Forms 1
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
Z Right click menu Outlook VBA and Custom Forms 4
N Right-click an address -> add to BCM? [OL2007] BCM (Business Contact Manager) 1
