mouse right click options
sabsac
Outlook 2019 64-bit
The mouse right click 'open' option is missing in outlook 2019 mail folder items.How to restore that option? kindly see attached screenshot for reference.
What makes you think there should be such an option on that right click menu? Mine (Outlook 2021) looks just the same as yours.
M office365 causing mouse lag? Exchange Server Administration 4
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
T Forwarded long email moves text to the right Using Outlook 1
L Add to Right Click Menu Using Outlook 10
B Right click-drag no longer creates hyperlinks Using Outlook 2
E Inbox view changed can't get it right Using Outlook 0
A viewing tasks - lower right - in email window Using Outlook 1
I Notification/Popup Box not showing on right side Using Outlook 1
Z Right click menu Outlook VBA and Custom Forms 4
N Right-click an address -> add to BCM? [OL2007] BCM (Business Contact Manager) 1
A edit right pane of mail Outlook VBA and Custom Forms 15
N Adding 'Add To Business Contacts' when right-clicking an email add BCM (Business Contact Manager) 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
T Is the standalone Outlook 2013 click-to-run or msi? Using Outlook 1
A Uninstall Click and Run Exchange Server Administration 2
A email folders appear empty, at first click Using Outlook 2
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
F When I click on link in email nothing occurs Using Outlook 7
M Programatically click the Send button. Outlook VBA and Custom Forms 5
