Click "A" to see all email from people with names starting with A... etc
tryptych
I have a user here who used to have their emails grouped alphabetically by the "From" field. It also used to have them all collapsed alphabetically, so he could just click "A" would expand & show email from everyone with names starting with "A". Clicking "B" would should expand & show email from everyone with names starting with "B". etc etc.
Anyone know how to get this is done? The setting is really well hidden.
Thanks in advance
Do you mean click the A on the keyboard or click an A button on the screen?
What version of Outlook did they use where they had that view?
The view I think you want is View tab > Arrangement: From; Expand/Collapse > Collapse all. That will group by email address but not by first letter. I don't know anyway to get them grouped by letter.
Outlook 2010. Very similar to if you click the VIEW tab then click "From" in the arrangement box, then Collapse All Groups. That sorts your email by the sender's name. You can click "Amanda Smith" and see all of the email from Amanda, etc etc.
But, this user wants it collapsed even further. He wants all the names collapsed alphabetically - so Amanda and everyone else starting with A is collapsed into a group called: "A"
I don't think that is possible - i tried using a card view but it doesn't group. It also also not very good for email. :)
What may be possible, but mostly unmanagable, is a custom view that only shows the the groups beginning with A. I haven't tested this view yet, but I think using From begins with A (on the Advanced tab) will work. You'd need 26 views... unless you combined seversl letters.
Using the From arrangement with the groups collapsed, she can jump to a letter by pressing it on the keyboard- this is what I'd do. (It's a handy shortcut and works in all folders and views in outlook.)
A email folders appear empty, at first click Using Outlook 2
F When I click on link in email nothing occurs Using Outlook 7
J Macro to open email (like double click) in Outlook Outlook VBA and Custom Forms 4
S mouse right click options Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
L Add to Right Click Menu Using Outlook 10
T Is the standalone Outlook 2013 click-to-run or msi? Using Outlook 1
A Uninstall Click and Run Exchange Server Administration 2
B Right click-drag no longer creates hyperlinks Using Outlook 2
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
M Programatically click the Send button. Outlook VBA and Custom Forms 5
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
M auto click hyperlink?! Outlook VBA and Custom Forms 1
M Auto click a hyperlink Outlook VBA and Custom Forms 2
H Program "Click on Ribbon Button" Using VBA Outlook VBA and Custom Forms 1
M How to provide custom functionality on click of "New"? Outlook VBA and Custom Forms 1
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
Z Right click menu Outlook VBA and Custom Forms 4
N Right-click an address -> add to BCM? [OL2007] BCM (Business Contact Manager) 1
R One Click business contact record creation - From an E Mail? BCM (Business Contact Manager) 1
P Contact Manger locks up Outlook when I click on folder? BCM (Business Contact Manager) 2
V List Click Outlook VBA and Custom Forms 1
U Adding multiple menu Items. Problems handling the click events Outlook VBA and Custom Forms 1
R SEND does not work first click Outlook VBA and Custom Forms 7
R Out of memory when click History button BCM (Business Contact Manager) 2
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
