Increase font size of message body
Jeremy87
Outlook 2013 64 bit
How do you permanently change the font size of the reading pane in Outlook? We've figured out how to use the scroll bar in the bottom right corner or ctrl+mouse wheel but that only changes the font size of the current email. As soon as you click another one the view resets.
We figured out how to increase the font size of the middle column (View settings>Other Settings>Column and Row font) but how do you increase the reading pane font size so that it stays?
I tried creating the macro but it didn't fix the issue unfortunately.
I tried changing the web settings inside Word and it didn't seem to make a difference. Did I need to restart after changing those settings?
O How to increase Font size in Outlook 2013 Using Outlook 1
C Increase Outlook 2013 message window row height Using Outlook 2
A OL 2007 problem - sudden large increase in message size Using Outlook 12
M Increase "Move To" List Length Using Outlook 3
J Can't Increase Outlook 2007 PST size Using Outlook 2
F Font Size Using Outlook 3
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
HarvMan Outlook 365 Inbox Font Using Outlook 8
T How to set Default FONT for Email composing ? Using Outlook 0
O Outlook - How to embed font ? (If at all possible) Using Outlook 2
P default font when sending email from browser Using Outlook 1
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
Marc2019 Outlook 2016 Font Problem Using Outlook 4
M Message list font changed after update Using Outlook 2
P Message List Font Changed Using Outlook 6
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
D font control by keyboard Using Outlook 2
M font format discrepancies with Quick Parts Using Outlook 1
Steven 2007 New PC vs Old PC - Micro Font on Inbound Emails :( Using Outlook 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
Rupert Dragwater Can't change font size Using Outlook 5
O How to paste website content using a specific font and removing URLs Using Outlook 2
T "From" field font size in table list of emails Using Outlook 0
S Default Font in body of Task Using Outlook 0
Diane Poremsky How to Change the Font used for Outlook's RSS Feeds Using Outlook 0
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
J Font size changed in new mail messages Using Outlook 5
Rupert Dragwater unable to change font sizes in some replies Using Outlook 3
