Outlook 2013 Possible interference by Telstra ISP with Hotmail Password
td47
Outlook 2019 64-bit
Visiting a relative in Perth Australia, my OL 2013 on my laptop keeps asking for the Hotmail password (it is MS Exchange mode as you know). However, there is NO issue with this account (the other 2 accounts, a POP3 and a Gmail IMAP are working fine), and I CAN successfully login via the "login.live" web UI access, using the same, correct password, that has not been changed, so i KNOW I have not been hacked. Never had an issue with the home ISP at all.
He is using the Telstra ISP, and I spotted an interesting post on another forum linked below, suggesting that Telstra is interfering in some way, stopping the Exchange server getting the password parsed. linking outlook to another server
Just to ask about another possible gremlin getting in the way of password authentication, I also saw this, in relation to the February posts about the infamous Microsoft shared calendar sync issues. I am not sure if this ADAL functionality is relevant or not:
1. Connect to Exchange Online With PowerShell
PowerShell:
Connect-ExchangeOnline
Set-OrganizationConfig -OAuth2ClientProfileEnabled $true
2. Regedit Users Computer
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\16.0\Common\Identity
Add DWORD 32: EnableADAL Hex Value:1
Close Outlook 365 reopen and there you go."
Outlook 2013 64 bit
I am having this same issue. It keeps prompting for my Hotmail password over-and-over. It's worked fine for years, no change other than what comes as part of mandatory Windows updates to Office. I tested to see if it was possibly corruption to my local OST account, or if it is a new policy by Microsoft, and I think it is the latter. Read how I tested this theory below.
I created a new login account on my PC so I would have a fresh user. I opened Outlook 2013 for the first time and tried to add my Hotmail account with the same results: It keeps asking for the password and cannot connect to setup. Mind you, I can still connect to my Hotmail account by logging in to Outlook.com, my phone, my PC at work with Office 365--pretty much anywhere not using 2013. Now, I also have a @Live.com account from Microsoft, and that still works under 2013. I'm not sure why they decided to block the combo of Hotmail and Outlook 2013 all of a sudden, but I would guess this is happening to every user of both. 😟
Do you have all office 20-13 updates installed?
Set these registry keys and see if it helps -
HKCU\SOFTWARE\Microsoft\Office\15.0\Common\Identity\
REG_DWORD: EnableADAL
Value 1
REG_DWORD: Version
Value 1
Outlook 2013 64 bit
Thank you Diane. I think my Hotmail has been offline for about 3 weeks now, and your suggestion did the trick! The second registry key for Version was already set, but the first one did not exist. I added it in:
Computer\HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\15.0\Common\Identity
Value 1
The second I opened Outlook, it was working again! Unfortunately, it looks like a ton of SPAM instantly began coming in as well. I think this may be stuff I deleted via other clients (phone, browser, work), or that had been automatically filtered out already while Outlook 2013 was not working. The SPAM only covered the dates while Outlook was not working for my Hotmail, and no further back than that. It seems to have stopped now.
Again, thank you very much for your help. I was about ready to give up and install a copy of Office from my work--but that would eventually expire if I change jobs, so I am glad to keep this one. Have a great day!
W Outlook 2016 MSI - Possible to make work with O365 modern Auth & Win7? Using Outlook 4
O Outlook - How to embed font ? (If at all possible) Using Outlook 2
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
e_a_g_l_e_p_i Is it possible to transfer things from one calendar to another Using Outlook 2
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Using Outlook 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
