Using Emojis in Outlook 365
HarvMan
OS Version(s)
  1. Windows
  2. iOS
  3. Android
Outlook 365 32 bit
Windows 10 Pro 22H2 and Outlook 365 version 2210 Build 15726.20202 Click-to-Run.
Trying to compose an HTML message and include some Windows emojis.
The Windows key + . opens the emojis panel.
However, clicking on the emoji does not transfer it into the email message.
Any advice ... thanks!
Yes, it's possible to use emoji in OFFICE 365. With mobile it's easy but with traditional PC it's critical.
Well, apparently it is not working in Outlook 365.
I am looking for a solution.
You can use emojis whenever you want to show how you feel about something. If you're angry, sad, happy, etc., you can use emojis to make your message stand out. Click Here
