Leaving ActiveExplorer open for editing after Sub is done
sierk
Outlook 365 64 bit
I have a bit of code (below) to add a formatted text string to an existing email. I would like to be able to edit the text and the email after inserting it. Presently everything works good, except that I have to run the "Edit Message" command as a separate action after the macro is done inserting the text. Thanks in advance for your help.
Set olItem = ActiveExplorer.Selection.Item(1)
With olItem
' "String" is a substitution for the formatted string portion which is constructed elsewhere in the program
.HTMLBody = "String" & olItem.HTMLBody
.Display
Set olItem = Nothing
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
V turn off shared calender reminders/leaving personal calender remin Using Outlook 7
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
H Select/Unselect items in ActiveExplorer by code? Outlook VBA and Custom Forms 2
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
T Cannot open .pst file Using Outlook 2
H Finding text in open email Outlook VBA and Custom Forms 12
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
Rupert Dragwater How to get Outlook 365 to open from websites Using Outlook 5
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
Commodore PDF attachments started to open in Edge Using Outlook 0
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
K Embedded photos no longer open with Photos or Photo Viewer Using Outlook 7
Witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
D after delete mail, open the next one Outlook VBA and Custom Forms 0
M outlook won't open! Using Outlook 1
M other user's mailbox won't open, forms disappeared Using Outlook 42
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
S Reminder Dialog Open Button Using Outlook 2
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
