Location Unsafe Warning for Links
LoztInSpace
Outlook 365 64 bit
Outlook version:     MS 365 Outlook v2403
Email type or host:    MS 365
MS 365 Outlook v2403 Build 17425.2058
Dell Inspiron, Windows 11
With any Outlook item I create- Email, Appointment, Contact or Task, when I add a link to a local file, I always get this message.
The above link points to a network drive but the message persists even if the link is to a file on the C: drive.
(If I try to use the UNC, after saving, the path is always changed to a a URL as above)
Unlike other attachment warning messages, even when I load Outlook as Admin, I don't get the option to disable the message.
I did a thorough web search and tried all the suggestions such as for the Outlook and Word Trust Center options and adding the "DisableHyperlinkWarning" to the registry.
Any ideas Diane?
Any ideas Diane?
Following.
I'm getting the same thing when clicking on an email appointment.
K Changing the Deleted Items location in Outlook 2019 Using Outlook 2
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
S Navigation Pane Location And Options Using Outlook 19
DoctorJellybean Use OST file location for fresh installation? Using Outlook 1
N Free/busy publish at http location does not work Using Outlook 0
L New Location for the Search Bar Using Outlook 6
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
S Moving .OST file location unsuccessful! Using Outlook 6
W Appointment occurrences change the location property Using Outlook 0
A Missing context menu on Location field Using Outlook 2
Diane Poremsky Meeting Location Warning Message Using Outlook 0
Kika Melo Change location of Outlook SecureTemporary Files Folder Using Outlook 5
Pierce007 Maps/location in making an appointment Using Outlook 2
J Live Meeting Location populate from body Outlook VBA and Custom Forms 4
K After Carbonite restore pst files are found in a weird location Using Outlook 2
M Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
Tech Checkers Make Outlook add Contact Card Address in Location Field based on Appointment Subject Name. Using Outlook 2
H Can't change the location of the Data File (.ost) in Outlook 2013 Using Outlook 2
R Outlook will not send from home location Using Outlook 6
S Workgroup template file location? Using Outlook 2
L Cannot update Location field in Contacts - Runtime Error 438 Using Outlook 0
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Using Outlook 0
S Holidays after 2012 & NOT displaying location Using Outlook 8
C Outlook 2010 - Default PST location Using Outlook 4
M Outlook 2003: Restore location Using Outlook 1
Z Mail delivery location - I think Using Outlook 1
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
J Remove location field from displaying Using Outlook 8
D Junk Mail location Using Outlook 1
D Extracting Location info from All Day Event in mailboxes into webpage Exchange Server Administration 3
J Move PST /changing default location in Outlook 2007 or 2010 64b on W7 64bit Using Outlook 2
G Pop up information location issue Using Outlook 4
C Multiple Locations in Calendar not showing 2nd location in invite Using Outlook 2
J .bcm file location BCM (Business Contact Manager) 1
S New Outlook Distribution List Location Outlook VBA and Custom Forms 2
B Cursor location in email item? Outlook VBA and Custom Forms 2
T Location field Outlook VBA and Custom Forms 1
H popup window "Location Information" Microsoft Office Outlook 2007 Using Outlook 3
