FUNCTION SEND/RECEIVE OUTLLOK AND VB6
EVB6.0
OS Version(s)
  1. Windows
Older version
Operating system::    Windows
Outlook version:     2003
Email type or host:    IMAP
Hi! I Using outlook with vb6, i wish to know how make for my app can send/receive mail, somebody can help please!!
You want to write a script that will trigger send and receive?
This is a VBA method -
Great!!
Dear Prof Diane
I'm new developer in VB6 and VBA. Is my first time that write a forums. I like learn about outlook 2003 for adding it in my proyect. My Proyect use vb6 with Microsoft Access, a proyect very small for pymes. it has six modules for control administrative.
thanks for answer my thread, i want ask you if you kwow some code for hide the next messenge appear to continuation
That security dialog should only show if you don't have an up-to-date antivirus or are using older versions of outlook... you can use Click Yes script.
There are registry keys that can block most of the annoying security dialogs, but they don't work in 2003 (to the best of my recollection.)
2007 is the oldest I have in this article -
L Outlook saved template function too limited Using Outlook 2
R Creating a user defined function Outlook VBA and Custom Forms 3
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
B Search function in Office 365 has stopped working Using Outlook 3
T Query About "Delay Delivery" Function Using Outlook 5
M Constant indexing/no search function Using Outlook 0
B Search function "to: ONLY Bob" Using Outlook 1
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
R searching a not function Using Outlook 2
E Outlook 2007 backup and restore function Using Outlook 2
R Serach Function Using Outlook 3
S Error from Folder.MoveTo function Outlook VBA and Custom Forms 2
J instr function Outlook VBA and Custom Forms 1
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
I Today function in Outlook Forms Outlook VBA and Custom Forms 1
J Include calculations in the lookup function Outlook VBA and Custom Forms 1
B Outlook Script ( using calendar function in a form) Outlook VBA and Custom Forms 3
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
Z WebView doesnt function with separate pst Outlook VBA and Custom Forms 3
M Automatically cc the "send on behalf of" account Using Outlook 18
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
C Synchronization and taking forever to send Using Outlook 2
T Outlook 2010 recipient no longer shows in 'Send To' Using Outlook 0
M Outlook 365 refuses to send email Using Outlook 0
