VBA Code Not Working correctly
Neil
Outlook 365 64 bit
Operating system::    win 11
Outlook version:     Microsoft 365 apps f
Email type or host:    IMAP
I have a VBA added to 2 Win 11 PCs. The VBA is identical on both PCs but yet it only works on 1 of the PCs. I get no error message but the VBA is supposed to send a BCC to an email address. The below is the VBA but I substituted a phony email address. As you can see, I got the VBA from this forum.
Sub Automatic_BCC_of_Sent_Email()
Dim objRecip As Recipient
Dim strMsg As String Dim res As Integer
Dim strBcc As String
' #### USER OPTIONS ####
' address for Bcc -- must be SMTP address or resolvable
' to a name in the address book
strBcc = "XXXX@OUTLOOK.COM"
Set objRecip = Item.Recipients.Add(strBcc)
objRecip.Type = olBCC
If Not objRecip.Resolve Then
strMsg = "Could not resolve the Bcc recipient. " & _
"Do you want still to send the message?"
res = MsgBox(strMsg, vbYesNo + vbDefaultButton1, _
"Could Not Resolve Bcc Recipient")
If res = vbNo Then
Cancel = True
Set objRecip = Nothing
' INSTALLATION INSTRUCTIONS Automatically BCC All Messages
' Open the VBA Editor using Alt+F11.
' Expand Project1 and double click on ThisOutlookSession.
' Copy then paste the macro into ThisOutlookSession. (Click within the code, Select All using Ctrl+A, Ctrl+C to copy, Ctrl+V to paste.)
' Don't forget to replace address@domain.com with the correct address.
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
S ThisOutlookSession in VBA not there anymore and code is gone Using Outlook 2
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
N VBA code to show today's date + a sequencial number in subject lin Outlook VBA and Custom Forms 1
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
