Messages stuck in Outbox - actually a Comcast mail client issue
PhilBurton
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    Wndows 10
Outlook version:     Office 365
Email type or host:    IMAP
Yesterday I sent four messages to my wife. She has received probably 30-40 total emails based on those four messages. I had this problem once before. In both the previous case and the current case, the emails contained JPG attachments.
I was unable to delete the messages in the Outlook Outbox, even after I deleted the Comcast OST file, and Outlook rebuilt my Inbox and related folders.
In both cases, I solved this problem by going to Xfinity website and accessed email. I deleted the Outbox messages, Then suddenly those problem Outbox messages disappeared.
I'm sure that this issue is due to a bug in Xfinity email. In the past, I have actually written paper letters to Xfinity, on JFK Boulevard in Philadelphia to ask that bugs be fixed. I got responses denying there was a bug, but then a few weeks later the bug "mysteriously" disappeared.
I'm getting pretty disgusted this Xfinity. I have their Quadruple Play service. but the only service that is issue-free is Comcast Voice (VoIP) I am aware that "sometime soon" email service will be discontinued. Their Home Security service has lousy support and overcharges for replacement door/window sensors.
You send the messages from Outlook and they were in an outbox at Comcast?
Do you use send immediately or have a scheduled send?
Typically, when you send using classic outlook, you can't delete mail that is waiting to send unless you go offline or use mcfmapi. You'll get an error message that it is sending if you try to delete it.
I’ve had a similar issue recently with Comcast and Outlook. Messages with attachments just sit in the Outbox, and nothing clears them unless I log into Xfinity webmail and delete them there. Seems like Outlook is trying to send, but something on the Comcast side gets stuck. Looks like a server-side problem.
I am the OP. I have run into this problem repeatedly, recently, always with messages with attachments. In one case, my wife received 47 (!!) copies of the same message with attachments. My solution was to put Outlook Send/Receive into Offline mode, and then delete the offendin message from the Outbox.
With Comcast, I have noticed multiple problems that are repeatable. I have even written letters to the Office of the CEO, only to receive a curt dismissal. In one case, when I was on the phone with second level support, the rep did not know that Outlook is an email client. You can't make this stuff up.
T SMTP messages stuck in Outbox Using Outlook 0
P Messages stuck in outbox and must be sent again. Using Outlook 1
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
W messages disappearing, not deleted Using Outlook.com accounts in Outlook 5
R Re-download past messages Using Outlook 3
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
G Question marks in messages Using Outlook 2
L How Stop Outlook Nag Messages Using Outlook 1
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
J Deliver new messages to New or Existing Data File? Using Outlook 2
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
