Using Netbook with Business Contact Manager
  • Thread starter Thread starter Donald
Donald
I would like to maintain a single data base with my sales people using a
"netbook" in the field. How can they utilize database when they are not in
the office?
Don
"Donald" <Donald> schreef in bericht
news:E2B529D8-21EA-47FC-969A-B8617553EDB8@microsoft.com...
> in
> the office?
> Thanks
> > Don
Haven't used this, but it should be possible to put a copy of the database
on a laptop/netbook and then sync the databases when they get back to the
office.
If you are running BCM 2007 , you should have the ability to create an
offline database .
Note: this option is only available if you connect to the shared database
Regards
Rahul Thomas [MSFT]
https://blogs.msdn.com/rathomas
"Donald" <Donald> wrote in message
> in
> the office?
> Thanks
> > Don
I am about to try the same thing following the direction from
http://office.microsoft.com/en-us/outlook/HA100676851033.aspx?pid=CH101207721033
Let me know if you have already done this, or I will reply IF/WHEN it works
for me.
> offline database .
> > Regards
> Rahul Thomas [MSFT]
> > in
> > the office?
> > Thanks
> > > > Don
T Using Exchange, the calendar cannot be synchronized. Using Outlook 3
