ItemEvents_10_OpenEventHandler does not respond on DocumentItems
  • Thread starter Thread starter mightyCoCo
mightyCoCo
I'm using the ItemEvents_10_OpenEventHandler to catch a open (double-
click) event on a Outlook item.
This works great on MailItem or PostItem types. However, Outlook
objects of the type DocumentItem dosen't seem to fire this event.
Instead I'm directly presented wih the document in it's native
application.
Is this a known restriction?
(Outlook 2007, VS2005)
thanks in advance,
-coco
According to the documentation the Open() event will fire if the
DocumentItem is opened in an Inspector. If it's not opened in an Inspector
but only in it's native application I wouldn't expect that event to work.
Check the count of the Inspectors collection before and after opening one of
these items and see if a new Inspector has been added to the collection. If
it has a workaround might be to handle NewInspector() and then check for
Inspector.CurrentItem.Class in that event handler. DocumentItem supports the
Class property and if the return from that is OlObjectClass.olDocument (41)
then you know a DocumentItem is being opened.
"mightyCoCo" <mightycoco@googlemail.com> wrote in message
news:802ee580-a7cf-48c1-9b13-24f9b272f4fa@r38g2000yqn.googlegroups.com...
> Hi,
> application.
> thanks in advance,
> -coco
On Jul 29, 4:33 pm, "
> Check the count of the Inspectors collection before and after opening oneof
> http://www.slovaktech.com
> "mightyCoCo" <mightyc...@googlemail.com> wrote in message
> > Hi,
> > application.
> > thanks in advance,
> > -coco
Hi Ken,
I tried using the NewInspector event handler. It's not fired either,
as Outlook doesn't seem to open an Insspector at all for a
DocumentItem.
Let's say the DocumentItem object in my Inbox is a .html object. If i
select it, in the preview pane the html file is rendered. If i double
click the object, Internet Explorer opens. The double click doesn't
open a new Inspector or triggers the Open event. It seems that Outlook
is directly running the process which is assigned to the object class
(Word for .doc, IE for .html, Notepad for .txt, etc...)
I wonder if I need to set the MessageClass of the object to something
else than IPM.Document, to trigger the event... But i guess, I'd loose
the document-specific icon in the Outlook list view then...
thanks,
-coco
e_a_g_l_e_p_i Why does MS do these things???? Using Outlook 4
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
J WshShell.Popup does't timeout Outlook VBA and Custom Forms 3
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 0
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 3
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
