get current position in message body of mailitem
  • Thread starter Thread starter sd
sd
hello
is it possible to get current cursor position (where next text will
appear) in message body of mailitem so that some predefined text/link
can be added at that position?
Version of Outlook? WordMail or not?
"sd" <dshubhangi@gmail.com> wrote in message
news:298105ae-68bd-4556-af02-63d418e22850@l5g2000pra.googlegroups.com...
> hello
> Thanks
I found cursor position related information on outlookcode.com for
both OL 2003 & OL 2007
Thanks Ken
I need to move to end of the word if the current cursor position is in
between the word and then insert the link.For OL 2007 using WordEditor
object it is possible.But for OL 2003 when word is not editor (for
plain text,HTML body format) how to accomplish this?
using redemption safeinspector I can insert the link at current cursor
position but how to know if current cursor position is in between the
word ?
Thanks again
You'd need to parse that out yourself. You'd get the position and the full
text and see if the position was at the end of the text or somewhere within
the text.
news:7f850884-51ca-460d-b46d-f191b530a7fa@y4g2000prf.googlegroups.com...
> word ?
> Thanks again
I was able to find out if the cursor is in between for Plain text
format but how to achive the same for HTML format ?SafeInspector has
HTMLEditor property but was unable to find if cursor is in between the
word.
Thanks again
HTMLEditor is an IHTMLDocument object, you would use that object model or
one derived from it.
news:2c07db9c-72c2-4bfe-810f-bfc57752be0a@y4g2000prf.googlegroups.com...
> word.
> Thanks again
Thanks again.I was able to move to next/previous word with the help of
HTMLEditor.But is there any way to find out the char at current cursor
position using HTMLEditor?(as I need to insert link to end of word if
cursor is in between the word otherwise just insert link at current
cursor position)
I don't do enough with IHTMLDocument to know that offhand. Take a look at
the object model for that object and see.
news:36d4768d-4d9c-4bc6-96ac-8ebc3e57f274@r24g2000prf.googlegroups.com...
> cursor position)
> Thanks
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
T current cursor position in the reply event Outlook VBA and Custom Forms 1
U Moving Microsoft 365 mailboxes from a different domain to our current domain Exchange Server Administration 2
N Having Shared Calendar shift to Current day Using Outlook 0
E Conditional formatting - when current account <> received account ? Using Outlook 3
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
F "This action is not available in the current mode" Using Outlook 0
J Old unread emails on current date (MDaemon Server) Using Outlook 1
T Attach Current File to a new Email Using Outlook 0
K Daily task list > show tasks on the exact due date and not on the "current date" Using Outlook 1
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
R Inbox search, current folder, it's in there-but not found. Using Outlook 2
sjbtax Auto Create new Task upon Current Task completion Outlook VBA and Custom Forms 28
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
M Change default Current View on People Using Outlook 1
C Either there is no default mail client or the current mail client cannot ... Using Outlook 1
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
C Hover display of DL shows original owner, not current Using Outlook 2
D Save Current email in Directory. Outlook VBA and Custom Forms 1
L create new mail item from current item Outlook VBA and Custom Forms 4
S Count of Contacts In Current View BCM (Business Contact Manager) 1
S VBA access current contact? BCM (Business Contact Manager) 1
X Re: how to access current text selection Outlook VBA and Custom Forms 1
T date/time field, current year Outlook VBA and Custom Forms 2
Q Remove filter from current view - outlook 2003 Outlook VBA and Custom Forms 4
D Re: How to specify the "current entry id" to GetItemFromID? Outlook VBA and Custom Forms 1
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
A Form Position with Dual Monitors Outlook VBA and Custom Forms 2
D Outlook Message Window Changes Size and Position Using Outlook 1
K outlook 2010 changes text tab position when sending Using Outlook 2
Commodore Renamed folder staying at the same position Using Outlook 3
