Form Position with Dual Monitors
Alan McGowan
Outlook 2013 64 bit
Is there any way to ensure a VBA form appears in the centre the screen that outlook is active in? If I have Outlook running on my primary screen I can use code to centre it on that screen. However if I have Outlook open on my secondary monitor the form is centred based on the combined with of both screens.
I have the form StartUpPosition set to 2 - CenterScreen and the following code under Userform_Initialize:
    Me.Top = Application.ActiveWindow.Top
    Me.Left = Application.ActiveWindow.Left
Hello, sure there should be. But I'm not sure if there's a chance via Lisp.
Just find out the location and the size of main window. Then you compute the upper left corner of your form depending the size of your form. I currently see no other way.
Stay Home, Stay Safe.
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
V Outlook Form ListBox is not editable Outlook VBA and Custom Forms 2
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Witzker Outlook 2019 How to get a Photo in a User Defined Contact form Outlook VBA and Custom Forms 2
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
V Latest Changes to form not appearing for some users Outlook VBA and Custom Forms 3
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
V Validating Outlook form with "OR" and "AND" Outlook VBA and Custom Forms 1
V Form data not sending for some users Outlook VBA and Custom Forms 2
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
D Emailed form is blank Outlook VBA and Custom Forms 0
