contents of BCM Contact groups not being displayed
L
Lieb EDV
Hi everybody,
I got a strange problem you might be able to help me with.
We have BCM since V2003 - recently updated to 2007. We have organized 3000
contacts in the database split in various groups from 5 to 150 contacts.
So it is a rather long list we have to look at. We we try to open one of the
groups at the end of the list it very often happens that the content of the
group is not being displayed. It opens up but nothing is visible. The bigger
the group the more likely it is.
In order to get this fixed we upgraded to Office 2007, we changed to Win XP
64 bit in order to adress those 8GB RAM... It just does not help.
Does anybody have a tweak how to get this done???
L
Lieb EDV
Correction:
It does not only happen that the group is empty, it also happens that the
group is shown partly. It does content 100 entries, but only 20 are shown...
If it makes diagnostics more easily :)
Thanks for your time
"Lieb EDV" wrote:
> Hi everybody,
P Table AutoFit > AutoFit to Contents Outlook VBA and Custom Forms 0
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
S Folders not showing all contents Using Outlook 1
M Custom form on one page to post contents on second page Outlook VBA and Custom Forms 0
Z Send mail and contents of body from ms word document Using Outlook 1
R compare folder contents to e-mail attachement Using Outlook 1
S Some people can not see the contents of my shared calendar. Using Outlook 2
I How do I completely delete contents of "deleted items" to reduce pst file size Using Outlook 1
S HTML Contents of an email Jumbled in Outlook 2010 Client Using Outlook 5
M Renaming or moving contents of a field BCM (Business Contact Manager) 0
S Outlook Distribution List contents Outlook VBA and Custom Forms 1
J move contents from hundreds of emails into excel Outlook VBA and Custom Forms 4
Q Custom Form and firing Revise Contents button Outlook VBA and Custom Forms 9
V Copying contents from one field to another field Outlook VBA and Custom Forms 6
