Advice on custom filtering
  • Thread starter Thread starter Christopher Long
C
Christopher Long
Ok so redemption didn't solve my earlier problem for scaling with the 32K
message rule.
If i create an outlook plugin that read the incoming messages and filtered
them manually though it would. The only problem is and although not necessary
i would like to do it in a way that would always be working behind the
scenes. By this i mean if someone checked on their exchange box via webmail
the add in would still be filtering mail at the server level.
What options would i have to do this? Is this something i would have to
create for exchange to act on a specific mailbox level or?
Essentially i want to scan each incoming mail message's body field, find a
specific line and if that line is found dissect it and move the message to a
folder based on whats in this line. Simple enough just need the options i
have to make it always run regardless of if the user is using webmail, mail
from their mobile device or outlook 2007 to read mail.
Thanks in advance.
In a way, you already answered your own question: "the add in would still be
filtering mail at the server level" means that unless Outlook is running
24/7 on the user's desktop, any filtering application that goes beyond
Outlook's capability for creating server-side rules would need to be
implemented at the server level, i.e. as an Exchange application, not an
Outlook add-in. That's a completely different type of application, with
dependencies on the specific version of Exchange involved. Exchange
documentation starts at http://msdn.microsoft.com/exchange/ with discussions
in the microsoft.public.exchange.development newsgroup or in the web forum
at http://forums.microsoft.com/TechNet/ShowForum.aspx?ForumID=838&SiteID=17
Sue Mosher
"Christopher Long" <ChristopherLong> wrote in
message news:F08CDD55-35CF-487F-971D-5FFD59FE8E1C@microsoft.com...
> message rule.
> necessary
> webmail
> a
> mail
> Thanks in advance.
Thanks. I had an idea of what i had to do but was just throwing it out there
hoping that perhaps i missed something or that there was an alternate option
for achieving my goals :).
Was trying the think tank approach.
Thanks again.
> > Sue Mosher
> > message rule.
> > necessary
> > webmail
> > a
> > mail
> > Thanks in advance.
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
J Want to 'modernise'(?) my email setup using Outlook. Any advice? Using Outlook 0
Horsepower Upgrade advice needed Using Outlook 3
K Master Category List / Contacts Public Folder Advice Using Outlook 4
Q Need advice for correct event Outlook VBA and Custom Forms 1
C Starting out and would like advice Outlook VBA and Custom Forms 1
D Custom Form Overwritten? Outlook VBA and Custom Forms 21
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
