href tags does not result in the full url with Redemption
  • Thread starter Thread starter DPM
DPM
I am using a program which reads emails from a selected folder of MS
Outlook(2003 SP3).
I have noticed the following,
- A mail has the <base href> tag defined in the header of the mail html
- The mail body has a relative tag with <a href
Once the MailItem.HTMLBody is read the relative tag(<a href>) is replaced
with the full url.
eg. The mail has the following html as the source
<html
<head
<base href="http://sample.com/aa/bb/cc"></base
</head
<body
<a href="dd">Text</a
</body
</html
The MailItem.HTMLBody returns the following
<html
<head
</head
<body
<a href="http://sample.com/aa/bb/dd">Text</a
</body
</html
But when Redemption.SafeMailItem is used its html results as per original
mail above(1st html) without the full url for the href tags.
Is there a facility in Redemption to read the html with the full urls as per
MS Outlook mail item?
Redemption ver. in use, 4.5.0.812.
Please advice.
AFAIK Outlook loads the HTML blob into an HTMLDocument object, which parses
the HTML.
Redemption simply extracts the HTML body as-is.
Dmitry Streblechenko (MVP)
"DPM" <aa@bb.cc> wrote in message
news:emLBFYrZKHA.196@TK2MSFTNGP05.phx.gbl...
> Hi,
> Outlook(2003 SP3).
> with the full url.
> <html
> <head
> </head
> <body
> </body
> </html
> <html
> <head
> </head
> <body
> </body
> </html
> per MS Outlook mail item?
> Please advice.
Dmitry,
Could you give some hints on how to use the HTMLDocument object so that it
is possible to generate the full urls.
"Dmitry Streblechenko" <dmitry@dimastr.com> wrote in message
news:OwuyjptZKHA.5652@TK2MSFTNGP06.phx.gbl...
> parses the HTML.
> > Hi,
> > Outlook(2003 SP3).
> > with the full url.
> > <html
>> <head
>> </head
>> <body
>> </body
>> </html
> > <html
>> <head
>> </head
>> <body
>> </body
>> </html
>> Please advice.
You'd think that would be easy... Essentially you need to create an instance
of the HTMLDocument object, QI it for IMarkupServices, then call
IMarkupServices::ParseString. That method fails a lot on real-world HTML, so
you'd then need to QI for IPersistStreamInit and then call
IPersistStreamInit::Load, which is asynchronous, so you'd need to wait until
HTMLDocument.readyState property becomes "complete" or "interactive".
news:u5ZomS0ZKHA.2164@TK2MSFTNGP02.phx.gbl...
> Dmitry,
> Thanks.
> > parses the HTML.
> >> Hi,
> >> Outlook(2003 SP3).
> >> replaced with the full url.
> >> <html
>>> <head
>>> </head
>>> <body
>>> </body
>>> </html
> >> <html
>>> <head
>>> </head
>>> <body
>>> </body
>>> </html
> >> original mail above(1st html) without the full url for the href tags.
>>> Please advice.
Thanks Dmitry.
news:uxznHO7ZKHA.4688@TK2MSFTNGP06.phx.gbl...
> instance of the HTMLDocument object, QI it for IMarkupServices, then call
> so you'd then need to QI for IPersistStreamInit and then call
> until HTMLDocument.readyState property becomes "complete" or
> "interactive".
> > Dmitry,
>> Thanks.
> > it is possible to generate the full urls.
> >> parses the HTML.
> >>> Hi,
> >>> Outlook(2003 SP3).
> >>> <html
>>>> <head
>>>> </head
>>>> <body
>>>> </body
>>>> </html
> >>> <html
>>>> <head
>>>> </head
>>>> <body
>>>> </body
>>>> </html
> >>> as per MS Outlook mail item?
>>>> Please advice.
B 2003 >> 2010 outlook today security changes (Iframes? Href?) Using Outlook 1
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
T Html tags in Message body Using Outlook 1
M Is there a reference for the valid XML tags and their options? Using Outlook 3
F "MSG" type attachments are stripped away when senand previewed with HTML tags. Using Outlook 3
P smart tags in Outlook 2007 Outlook VBA and Custom Forms 4
Q Smart Tags - Telephone Number recognizing the contact information Outlook VBA and Custom Forms 3
e_a_g_l_e_p_i Why does MS do these things???? Using Outlook 4
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
J WshShell.Popup does't timeout Outlook VBA and Custom Forms 3
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 0
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 3
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
