Html tags in Message body
ticache
Hi I need to create HTML tags in email message body. For example i would like to have four boxes on left side of message body (purpose, features, events, resources). When user clicks on purpose, the content relavant to the purpose should be displayed. If the content goes over 1 page then previous and next buttons should help user to move through pages. I am not sure how this can be done in outlook 2010.
I used website tags template in publisher to create this navigation but when I publish the documnet for email only one page is visible. I am not seeing that navigation. Please help
regards
Sridhar
F "MSG" type attachments are stripped away when senand previewed with HTML tags. Using Outlook 3
Albert McCann Outlook 2021 Outlook Display of HTML Email from two senders is glitchy Using Outlook 0
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
M HTML email signature in Outlook Using Outlook 3
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
George Simpson "Switch to HTML" in Outlook 2016 notes field Using Outlook 1
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
S Outlook 2013 doesn't download html messages Using Outlook 0
cabinet guy permanent response in html Using Outlook 1
C Signatures in HTML emails Using Outlook 5
I Outlook 2013 Appointments not in HTML Using Outlook.com accounts in Outlook 2
B Replies never HTML Using Outlook 2
Diane Poremsky Outlook crashes when viewing HTML Messages Using Outlook 0
Diane Poremsky Create a New Message using an HTML File or Stationery Using Outlook 0
V incorrect html signature printed Using Outlook 2
Z alter the timeout for how long outlook looks for a content-server on an HTML-email? Using Outlook 5
Y HTML Emails Using Outlook 1
A Lync meeting in outlook lose HTML formatting Using Outlook 3
C Outllok 2010 (14.0.7015.1000 (32bit) converts html mail to rich text when move Using Outlook 1
T HTML email for internal mesages and Text only for External? Using Outlook 1
M Unable to read HTML Using Outlook 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
D Saving outlook emails in html and attachments Using Outlook 4
T Forcing HTML for replies in Outlook 2013 Using Outlook 4
M HTML mails apprearing broken in outlook 2013 Using Outlook 5
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
J Outlook is not parsing html email, unreadable and attachment not decoded Using Outlook 1
A Calendar to Web HTML - Multiple Files Using Outlook 1
S HTML Contents of an email Jumbled in Outlook 2010 Client Using Outlook 5
C Save as HTML for multiple emails Using Outlook 1
G No word wrap in HTML email. Using Outlook 8
M Mail in HTML format can't be sent if url or number is in the body Outlook 2010 Using Outlook 2
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
