RDO: using TypeOf to determine [OOM] Class
  • Thread starter Thread starter Mark McGinty
Mark McGinty
I've been using this successfully to determine whether an item object is a
contact, task or appointment, but I have a related problem: Since all item
types derive from RDOMail, how do I determine that an item is an email
message? (MessageClass = "IPM.Note" by default.)
At the moment I'm testing for all of the RDOMail-derived types, and assuming
that if it isn't any of them, it's an email... (I want to remove all
dependency on the MessageClass string for this level of test.)
Is there a more efficient way to do this?
TIA,
MM
Re: using TypeOf to determine [OOM] Class
That is as good as it gets... If the items is not one of the sepcial items
(such as RDOAppointmentItem), treat it as a generic RDOMail. object.
Dmitry Streblechenko (MVP)
"Mark McGinty" <mmcgintyNG@sSpUaCmKSdeprecatethis.com> wrote in message
news:ufZeOJu3KHA.1624@TK2MSFTNGP06.phx.gbl...
> item types derive from RDOMail, how do I determine that an item is an
> email message? (MessageClass = "IPM.Note" by default.)
> assuming that if it isn't any of them, it's an email... (I want to remove
> all dependency on the MessageClass string for this level of test.)
> TIA,
> MM
M RDO Question Outlook VBA and Custom Forms 2
S Failed to create an RDO session instance: Class not registered Outlook VBA and Custom Forms 1
