Using custom form
  • Thread starter Thread starter Anthony Lee
Anthony Lee
hi!
i've been learning a lot thing in this community.
but i couldn't find the way which i'm looking for.
now i'm using outlook 2003 version.
when i open mail received , i'd like to use custom form i/o MASSAGE
because i want to add book mark , add comment and to divide each mail
according to my idea (for example, for this mail i have to check again in the
future, and for some mail, i should make a report for my job)
of course, i've looked out other site. but found that for outlook 2003,
changing the default form is impossible(i'm not sure that this is correct)
when i open received mail, print out then input some data in excell or in
access
it's not good.
anyhow somebody help me solve this form.
and i've used excel's vba, and i've used access too.
please give me a little bit hint.
b.rgds
You'll have to be more specific about what you're trying to do. For example,
you may know what "divide each mail according to my idea" means, but no one
else here does.
Sue Mosher
"Anthony Lee" wrote:
> hi!
> access
> it's not good.
> b.rgds
thanks a lot for your reply
the thing that i want to do is to use custom form when receiving some email.
not default form.
how can i do this?
b.rgds
> else here does.
> > Sue Mosher
> > hi!
> > access
> > it's not good.
> > b.rgds
C Using my custom form with a public folder Outlook VBA and Custom Forms 6
C Deployment of custom form using "setup.exe" Outlook VBA and Custom Forms 4
J Outlook 2007 using custom form created for Outlook 2003 Outlook VBA and Custom Forms 2
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
L reply to message using a custom template Using Outlook 1
W Using a PropertyAccessor custom datetime property in Views Outlook VBA and Custom Forms 3
T What is the best way of using the Classic Outlook client to change my email address? Using Outlook 4
