Hyper links not working in forwards or replies
redman
I saw this posted about a year ago, but there was no solution for it, so I'm reposting.
In my signature, I have two hyperlinks, but when I try to forward a message,
it changes to plain text and it does not include the hyperlinks. I have tried
changing options/settings but I can't seem to figure it out. Can someone tell
me how to fix this problem. I think that maybe changing a setting to always
let fwd messages be HTML or Rich text may fix this, but I have had no luck...
Thanks in advance!!!
I have this same problem, the links only show in new messages and not in replies or forwards. I'm using 2003 on an exchange. Any help is appreciated!
When you reply or forward plain text messages, Outlook uses the plain text signature. You can't change the behavior, short of changing the message format before hitting Reply or Forward.
How are the hyperlinks formed in your signature? Like This or this http://www.slipstick.com ?
If like This do you see the display phrase in the signature? You can go to %appdata%\microsoft\signatures and edit the text file to include the url.
ETA: you'll need to use http://www.whatever.com/ format in the plain text sig.
Since this original question was posted has their been any updates to a solution?
I to would like to have my reply/forward messages use the hypelinks and not the URL's.
L Location Unsafe Warning for Links Using Outlook 1
L Outlook attachments from OneDrive as links Using Outlook 0
A Links in email getting error message about group policy Using Outlook 4
J Outlook 365 Emails showing as links and text only Using Outlook 4
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
Diane Poremsky Using Outlook Links Using Outlook 0
J Outlook 2016 is killing me with object.links Outlook VBA and Custom Forms 2
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
B Assistance with Deprecated .Links Property Outlook VBA and Custom Forms 2
M Outlook 2013 conversation view ... missing links Using Outlook 3
W Add to Calendar links - auto accept with macro Using Outlook 1
L UserForm Code For Contact Links Using Outlook 76
R conerting links to images Using Outlook 3
S Question regarding contact links Exchange Server Administration 37
mrje1 mailto links in browsers don't open up outlook email Using Outlook 2
J links won't open from Outlook Using Outlook 1
P E-mail links Using Outlook 3
I Links not working after un-installing Google Chrome Using Outlook 2
S Embedded links Using Outlook 1
S Outlook 2010 Ribbon - Creating Links To Websites or EXE Files Using Outlook 4
L Links do not work in my e-mails Using Outlook 1
K Can't use links in Outlook custom form text field Outlook VBA and Custom Forms 1
J Unable to open links in Outlook mail Using Outlook 2
E How does BCM links items BCM (Business Contact Manager) 1
M Fixing broken Journal links to Contacts in Outlook 2007 Outlook VBA and Custom Forms 3
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
