How to create add-in to delete duplicated contacts
  • Thread starter Thread starter VMSantAnna
V
VMSantAnna
Hi all,
I'm trying to create a sub to compare and delete the contacts that are
duplicated, with no success untill now.
Also, I'm tryin to create it as an add-in to be placed as a menu item or
on option item.
Any help will be great.
Thx you all.
Vitor
If your code raises an error, show it here and we can see what the problem
is.
Best regards
Michael Bauer
Am Sun, 19 Apr 2009 00:34:05 -0300 schrieb VMSantAnna:
> Hi all,
or
> on option item.
> Thx you all.
> Vitor
anoble1 How to create an email with a link to add a calendar appointment Using Outlook 1
M How to Create Macro in Visual Basic to add Contacts from Personal Folder Using Outlook 4
P How do I create a macro to add contacts from email messages? Outlook VBA and Custom Forms 1
T Create a group from a large To distribution list Using Outlook 3
