Outlook Contacts 2010 problem with Notes section configuration
So after years and several versions of Outlook including through Outlook 2013 the replication of URLs and email addresses continues in the Contacts Notes section. This is happening with a majority of my clients and with my contacts as well. I have to routinely remove the dozens of duplicated email addresses which eventually fill up the notes section. Specifically an email address in the notes section like user@domain.com turns into user@domain.com <mailto: user@domain.com <mailto: user@domain.com <mailto: user@domain.com >>> . This replication sometimes goes on for dozens of times. This was the original issue mentioned in this thread and I don't see that it has been addressed here or anywhere else. Does anyone have a solution yet to this annoying bug?
D Outlook 2010 contacts syncing intermittently via Outlook Connector Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
O Outlook 2010 Contacts Using Outlook 3
S Seeing Custom Fields in Contacts (Outlook 2010) Using Outlook 0
T Outlook 2010 - Contacts associated with an e-mail address Using Outlook 1
L Suggested contacts are not retained after exiting Outlook 2010; Windows 8.1 Using Outlook 4
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
N iCloud deleted my Outlook 2010 contacts Using Outlook 1
C Custom Form Outlook 2010 Contacts Using Outlook 3
D Search iCloud contacts from Outlook 2010 CTRL-E Using Outlook 4
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
E My Outlook 2010 contacts list was hijacked! Using Outlook 10
S How to set Company as default "File As" in Contacts for Outlook 2010 ? Using Outlook 1
S Outlook 2010 Mobile Contacts Using Outlook 1
S change default contact list in Outlook 2010 to "contacts" rather than "global" Exchange Server Administration 1
S Outlook 2010 Email address dissapearing in SOME of contacts Using Outlook 2
B Can't Remove Shared Contacts Folder in Outlook 2010 Using Outlook 2
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
M Searching Outllook 2010 shared contacts from Outlook 2007 Using Outlook 4
M Error Messages when exporting Outlook 2010 Contacts to a CSV (DOS) or Excel Using Outlook 2
R How to backup contacts in Outlook 2010 as business cards Using Outlook 1
M Outlook 2010 Contacts - mailing lists Using Outlook 2
T Outlook 2010 lost all eMail addresses from contacts Exchange Server Administration 4
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
