Filter which removes Display Names from incoming emails.
Hi!
I am looking for a means whereby the sender's Display Name can be stripped from any incoming email, prior to further processing by Outlook.
This facility achieves the desired result, but cannot be used with my own Outlook 2007/Gmail.IMAP set-up:
http://www.m86security.com/kb/article.aspx?id=10437.
Does anyone know an alternative method, please?
The purpose is to confine Outlook to using a sender's raw email address only, for all display purposes. If the sender's Display Name, attached to an incoming mail, is removed completely, then Outlook will be forced to use and display only the sender's email address.
This thread applies, albeit tangentially:
?86266-Customised-To-CC-BCC-and-Have-replies-sent-to-columns-in-message-lists.
Views welcome!
With regards,
William Lambton,
Ireland.
Thanks very much for that, Slipstick. I have been using the Neostorm .cfg for some time, and very useful it is. However, the equivalent .cfg cannot be written for recipients' addresses. So, to deal with that, I am now approaching the idea of a Display Name filter. This would obviously eliminate all freshly-arriving externally-generated Display Names from Outlook (but wouldn't affect those already in situ), which would not necessarily make the facility widely popular.
The stripping device would probably have to sit between Outlook and the server. The M86 Security device, which I linked to (above), does that. It calls for the emails and hands them on to, say, Outlook. However, such security devices are effectively their own, stand-alone email clients (as I understand it) and include many other features, which I personally don't need.
So, I am working on the premise that quite a small add-on only would be needed, attached to Outlook, through which any incoming mail item would pass, before Outlook proper set to work on it.
William.
R unable to filter tasks when start date is on or before today Using Outlook 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
Jennifer Murphy Spam filter not working Using Outlook 13
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
G How to filter by the format of an email address Using Outlook 6
S Mail filter recieved before the last 2 working days Using Outlook 1
Liza Creating a rule in outlook to filter messages Using Outlook 0
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
Diane Poremsky Filter and Save Contacts to a CSV File Using Outlook 0
Fozzie Bear HomeTab Email filter "Greyed Out" in Outlook 2013 Exchange Server Administration 3
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
J Outlook VBA for Email Filter Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
M Filter today's mail Using Outlook 2
J Task Filter for Status OR One Month Using Outlook 4
R Filter Views by Category Using Outlook 2
D Junk Mail filter Using Outlook 1
S Filter by accounts but communicate to all linked contacts BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D How Would I Write This Filter? Using Outlook 3
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
P BCM Review & Filter BCM (Business Contact Manager) 1
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
M Create search folder filter that converts UTC time to local? Outlook VBA and Custom Forms 9
E DASL Filter doesn't work when defined programatically Outlook VBA and Custom Forms 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
K Can I filter by fields 'containing' specific words? BCM (Business Contact Manager) 1
