Notification/Popup Box not showing on right side
imfarhan
Hi ,
I have setup the rule , when my name is on CC from sender , the email goes to the particular folder i.e. "CC" folder and it doesn't go directly to inbox. When I get those emails, I can't see the the popup/msg(Email notifier) which normally comes on the right side of the desktop when ever I get emails.
For normal emails which directly come to my inbox I can see the email notifier (popup) on thei right side of the window.
I hope it make sense.
Appreciate your help
How can I see the notifier when its showing normally when emails is arriving which meant to go to particular folder except inbox
Outlookversion I'm using is 2007
Kind regards,
Farhan
What type of email account? If Exchange with server side rules, its to be expected because the message is moved on the server. For other account types, you can add an action to display an alert (a blue window alert) and/or play a sound.
W Outlook Desktop alert, notification, popup - turn off programattic Outlook VBA and Custom Forms 1
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
I Google Calendar <calendar-notification@google.com> appearing as a duplicate entry Using Outlook 2
A New email notification on shared mailbox Outlook VBA and Custom Forms 0
nkhan123 Notification Using Outlook 1
R Outlook and the Windows 10 notification center Using Outlook 8
M Email notification on creation of an appointment shared calendar? Outlook VBA and Custom Forms 3
R Notification/alert when an email has been sat in inbox for a set period of time Using Outlook 1
S Macro to create notification emails Using Outlook 1
K How to make email notification in Outlook 2013? Using Outlook 1
C [outlook-users] email notification Using Outlook 7
B outlook 2010 - email sound notification Using Outlook 3
F Email notification if notification email fails Using Outlook 1
D How Can I Receive Email Notification On Multiply Accounts in Outlook.docx Using Outlook 2
J Re-enable the junk mail notification. Using Outlook 6
B automate email message on Outlook Calendar notification alerts? Outlook VBA and Custom Forms 1
A Notification for Multiple Email Accounts Outlook VBA and Custom Forms 3
J WshShell.Popup does't timeout Outlook VBA and Custom Forms 3
GregS Outlook 365 blocked by Google popup Using Outlook 2
I Windows 10 - .msg files on disk show Explorer popup error Using Outlook 5
T Unable to 'Upload a file' using popup 'Browse' button Using Outlook 0
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
P Country name no longer shows in Phone number popup? Using Outlook 5
P POP mail password popup after I deleted the accopunt Using Outlook 6
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
M Cannot change category in inbox; Can change it in popup Using Outlook 0
C Disabling "Do you want to save changes?" Meeting Popup? Using Outlook 0
T Outlook 2007 SSL selfsigned certificate how to stop security popup everytime? Using Outlook 10
H Popup asks for password of an email account Using Outlook 1
M Files in "Attach File" popup menu no longer alphabetical Using Outlook 3
H popup window "Location Information" Microsoft Office Outlook 2007 Using Outlook 3
D Suppress Popup Outlook VBA and Custom Forms 1
V CommandBar popup Outlook VBA and Custom Forms 1
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
