Help with random numbers in autocomplete emails
Hi, we are seeing issues with random numbers appearing in Outlook autocomplete entries for users inside our organization. This started happening after installing a new Small Business Server (pulled old clients off old SBS, added them to new SBS, restored Exchange from tapes/PST files).
The problem is that I already went to each client and deleted the old autocomplete entries but they keep showing up - I am guessing due to replying/forwarding older emails. Now, my users are seeing tons of bouncebacks when sending to internal users which is a huge problem!
I found these forums by way of Google and the following thread which makes it seem that I should be able to fix this:
<link coming="">https://forums.slipstick.com/thread...complete-global-address-list-issue-display-n/
Any suggestions? This is a huge problem!
Thanks for any help!
You can use ADSIEdit edit to edit the actual address in the active directory. That is the ony fix if the address ihas changed.
How is the entry formatted? I know when you move servers there may be subtle differences in the x500 address that will cause this.
D Request help with a macro for forwarding email Outlook VBA and Custom Forms 5
