Color catagories
Skipper Dan
From one day to the next my color categories changed from the skinny multiple to expanded and with names. I would like to change it back to like before. When I have more than two categories for an item I would like them to switch to the skinnier type without any words after. Or at least get rid of the words. I do not mind the words in the open document but I would like to keep the column the same size all the time and have them all show up.
Dan
larry
This is in the message list? You need to reset the view. Right click on the row of field names and choose Custom...then Reset. (Reset might even be on the right click menu, it is on some versions.)
If you mean in an opened message, that is how it is in opened messages.
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
M Emails sorted by conversation including replies and categorized by color. Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
C Color Code New Calendar Items Using Outlook 2
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E Outlook 2016 Default Blue Color Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
J Color Alignment on the Calendar? Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
B Sub Calendar-Color Coding Issue Using Outlook 4
D Calendar - color coded items are now the same color Using Outlook 2
B Color Categorizing 365 Using Outlook 8
J Change Default View - Color and font Using Outlook 3
Tom.Schaefer Color for Mail-folder in OL2013 Using Outlook 1
K Color Categories for Accounts and Contacts BCM (Business Contact Manager) 0
M Background Color? Using Outlook 1
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
D Background color for an entire day in Outlook 2010 Using Outlook 1
Commodore Color options in 2010... Using Outlook 0
U Color coded contacts Using Outlook 4
T Setting Color codes for each user of a shared Calendar Using Outlook 1
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
M Assigning a specific font color to new emails using rules when they arrive Using Outlook 3
L Background Color Is An Issue Using Outlook 3
L Color Using Outlook 49
J Color categories with shared mailbox Using Outlook 1
F Color Coding Emails - Outlook 2007 SP-3 Using Outlook 1
C Apply Category Color for Appointment Background Color Using Outlook 2
N Changing background color on replies and forwards Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
M How do you change the obnoxious color of the email headers on Outlook 2013? Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
J Text color when creating a new Task is not consistent Using Outlook 1
S Outlook incoming mail & color blindness Using Outlook 2
M Auto-color all Calendar items based on condition: Private Using Outlook 6
