Outlook 2010 Instant Search Pops When I Click
loghyr
I am running Outlook 2010 with Exchange, under Windows 7
With Outlook open, I click in the Search field at the top of the items column;
Immediately the area below the search box expands to reveal ten (10) additional fields (see attached)
My coworkers, with the identical versions of Windows 7 and Outlook, on the same Exchange server, are unable to get this to occur with their Outlook Instant Search field. Clicking in the field pops nothing.
We have compared and matched all the Search, Instant Search, and View settings in Outlook. And yes, we've made sure that Instant Search is enabled under Programs and Features.
How can my colleagues get the additional Instant Search fields to "pop" like mine do?
Try selecting all of those fields on the Search ribbon on the other computers - as long as you don't 'x' them to close a field, search should always include those fields.
I'm not sure how to do that. Attached is another screen shot of my search, with its extra fields, plus the search ribbon - I don't see any way to select fields on the ribbon...
Here is a quickie video - ignore the angry birds in the background, I'm out of town for my daughters wedding and my grandkids were playing my ipad.
[video]http://www.screencast.com/t/m9k81RzsdbGi[/video]
Thanks! I need to have our Security group temporarily unblock "screencast" from the company's URL blacklist so I can watch it...I'll post after I get access...
I'm surprised they block screencast - i can upload it to my server instead, once i get on a real computer. (I'm traveling and on an ipad right now.)
You are the bomb! This worked great, you and I are heroes now....
Thanks so much!;)
S Instant Search in Outlook 2010 Using Outlook 32
S Outlook 2010 Terminalserver Cache Mode Instant Search Using Outlook 4
F Outlook 2010 and Hotmail Using Outlook 1
