OL2010 Calendar Appointment Highlighting Text issue
RepublicsFury
Outlook 2013 64 bit
I'm using MS Outlook 2010 and am unable to use the mouse to highlight text. I've searched several places and can't find (though I seriously doubt I'm the only one having the issue) a thread here or on another forum or discussion group discussing the issue.
Opening an appointment it has the area below the start/end time to type text into. I can't highlight that text with my mouse. I am able to use the keyboard and arrows to do so but not the mouse. Any suggestions would be appreciated.
Karl
Yes I'm using iCloud and the double/tripple works but it's not allowing selecting partial or across lines. The Shift+arrow works and I think it's the only way to solve the issue currently:p. Did you come across a different way to solve the problem?
RF
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
J Calendar search failing & wrong indexlocation showing..OL2010 Using Outlook 3
R New computer, OL2010 unable to display shared calendar appointments Exchange Server Administration 3
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
T From OL2010 Pro to OL2003 Pro Using Outlook 4
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
B OL2010 and install custom WYWO form Using Outlook 1
O Form cache size for OL2010 is set up to 0 Kbs, but sometimes ! Using Outlook 8
P OL2010 - custom form contact picture Using Outlook 0
B Updating Macro to OL2010/32bit Using Outlook 8
J OL2010 Create a new task while off line Exchange Server Administration 3
M How to skip weekends on recurring appointments - OL2010? Using Outlook 4
P migration issue from OL2003 to OL2010 with custom contact form Using Outlook 7
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
B OL2010 - signatures while forwarding tasks or appointments Using Outlook 2
T Can't remove NEW GROUP in OL2010 Using Outlook 1
S OL2010 - choosing to not save inline images Using Outlook 1
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
T Defer Sending emails in OL2010 Using Outlook 1
G Keyboarding with HTML Email in OL2010-64bit Using Outlook 0
B how to debug in OL2010? Outlook VBA and Custom Forms 3
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
C Create a Ribbon for the OL2010 Explorer Outlook VBA and Custom Forms 1
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
