How do I link a drop down box to a percent complete box
Mark
I am trying to create a custom form.
I know that status and % complete are linked fields that can't be edited. Is it possible to create a custom one however?
For example, I want a drop down list to display items such as: Not started, in progress, at ECR approval, at ECO approval, complete etc. And link to that: 0%, 5%, 90%, 95%, 100% etc.
Thanks in advance,
Mark
Do you want two custom fields or one that links to the % complete field? You can create 2 fields and can do something like that with coding but I'm not sure if you can use the existing % field.
It doesn't have to link to the standard %complete but would be good if it could.
Can anyone help with this?
In the attached image, at the bottom in the Purchase Order Status section I want to be able to link a few details.
Ideally I want the default to be: PO Raised, then when this gets sent to someone for approval, I want them to be able to change this to approved and it gets sent to another email address. I then want the final person to implement something elsewhere and then change the status to complete and this puts a date in the PO sent box.
Is this all possible?
I'm not too fussed about the % complete box.
A Opening a link from an email automatically Outlook VBA and Custom Forms 0
A Opening a link from a specific sender automatically Outlook VBA and Custom Forms 4
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
P How did hacker cause link to delete and archive containing email? Using Outlook 6
D launching a link in google Using Outlook 1
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
J Tasks - the missing link... for me at least. Using Outlook 4
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
G Outlook item link Using Outlook 0
S Calendar loops when clicking on calendar link to start it Using Outlook 1
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
D Link contacts with emails Outlook VBA and Custom Forms 11
T Automatically open link in email received Outlook VBA and Custom Forms 33
G Outlook email link mistake Using Outlook 1
iwshim Can I add an Unsubscribe link to Outlook outgoing email? Something like this? Using Outlook 1
M Link POP account with Outlook.fr Using Outlook 1
anoble1 How to create an email with a link to add a calendar appointment Using Outlook 1
S Possible to link to ics file without importing? Using Outlook 4
C From an email open a link but not the new window Using Outlook 1
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
T link multiple emails to one project in one way BCM (Business Contact Manager) 1
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
R Mailto link inside Outlook 2010 being cached? Using Outlook 1
A Outlook to Onenote link stopped working Using Outlook 7
J Nothing happens after clicking on the link in my emails Using Outlook 3
K Outlook 2010 - Link Outlook items to tasks? Using Outlook 1
J Link Contact to specific from address Using Outlook 2
A meeting notes (send to onenote) link in 2013 Using Outlook 5
B link to group schedules from Today screen Using Outlook 2
D Link multiple messages to opportunity BCM (Business Contact Manager) 1
R Add a link to a custom form Using Outlook 0
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
F When I click on link in email nothing occurs Using Outlook 7
S Clickable link on Outlook HTML Body Outlook VBA and Custom Forms 3
C How do I enable a link in an e-mail in Outlook 2007? Using Outlook 4
S Unable to link the BCM contacts twice with account contacts BCM (Business Contact Manager) 1
S Reminder (Off / On) Link With Reminder Data/Time Outlook VBA and Custom Forms 3
J Loading and Scaning a link inside of an email and ... Outlook VBA and Custom Forms 1
G regex to search for link in attachments? Outlook VBA and Custom Forms 2
