Update existing rule using VBA
darkwolf.mca
Hi all,
I'm newbie so please be patient :o
I trying to understand if it exists a way to update an existing rule using VBA.
Within a routine I create a rule like the following:
Set myRules = Application.Session.DefaultStore.GetRules()
Set rl = myRules.Item("Photos")
Set olConditionSubject = rl.Conditions.Subject
With olConditionSubject
.Enabled = True
.Text = Array("White", "Black")
myRules.Save
and that's fine... it works as desired... but how can I add one or more words?
If I create a new routine with
.Enabled = True
.Text = Array("Red", "Green")
it replace the one already present... how can I update the rule using VBA so it can filter on all words?
Cheers
Mauro
I'm (almost) always patient. :)
I'll check, but I would try reading the rule then updating it - not sure it will work, but I think that is the angle you need to use.
> Text = Array(txtRule, "Red", "Green")
Great Diane,
that's could be really the solution I was looking for: read the values from the existing rule in a variable, put the variable in the array with adding words... but:
how can I do it? :(:confused::(
Thx
Mauro
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
Bachelle Macro to Update Existing Task from New Email Outlook VBA and Custom Forms 3
P Update the existing Contact item Outlook VBA and Custom Forms 1
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
icacream New password won't update Using Outlook 2
O Batch update calendar Using Outlook 3
R Outlook 365 update sets delete from server flag Using Outlook 1
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
Jennifer Murphy Grant R/W (update) access to a friend Using Outlook 3
L Favorites don't update Using Outlook 1
M Message list font changed after update Using Outlook 2
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
O Windows 1803 update : QAT and toolbar changed, language pack gone... Using Outlook 5
K Update Appointment category when changed in Excel Using Outlook 3
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
C Update Notes for Meeting Attendees Using Outlook 8
A Attendee Update Outlook Meeting Invite Using Outlook 0
Diane Poremsky Outlook Email Security Update Using Outlook 0
S Task Update coming as email and not updating task Using Outlook 3
Diane Poremsky Remove Office 2013 Update Banner Using Outlook 0
B IMAP folders don't update when Outlook 365 opens Using Outlook 0
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
Diane Poremsky Task Request Status Update Address Missing Using Outlook 0
CWM330 Importing from Eudora Update Using Outlook 5
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
I Microsoft Security Update KB3097877 Using Outlook 14
S Outlook 2010: October 2015 Update Using Outlook 0
