Slow Calendar Synch Between Outlook 2013 and iCloud
richd48211
Outlook 2013 64 bit
I'm running Outlook 2013 and iCloud. When I add an Outlook Calendar entry (in my iCloud Outlook calendar), Outlook freezes for 5-7 seconds (I get a Not Responding message), presumably while Outlook syncs with iCloud, before successfully adding the entry. This occurs when using a high-speed Internet connection. Is there a way to schedule the sync to happen at certain times so I can batch the sync vs. iCloud syncing with every entry?
We are experiencing the same issue. Have you every found a solution?
You can't schedule the sync - and it shouldn't freeze. i'd try signing out of the iCloud and signing back in/ Oh, and what security software do you use? It could be scanning the sync.
I'm having the same problem...no security running. Do you log out and back in inside Outlook?
Open the iCloud control panel app - it should be in your notification tray. Close outlook and sign out of the iCloud panel, then sign back in. When asked if you want to keep a local copy, say no.
I removed the iCloud then signed back in, setting it up again. I'm still having the same problem. When I disconnected the iCloud it worked fast (because it wasn't syncing with every Outlook change). After I connected again it slows the same 5-7 seconds like before. I think its sending every change to the cloud and it causes a delay vs when I was using Google Calendar Sync where it would batch and send every 15 minutes or so.
Am I missing something?
Commodore Slow calendar Using Outlook 0
N Outlook is very slow Using Outlook 0
1 Opens Slow Using Outlook 4
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
D Very slow when digitally signed Exchange Server Administration 0
Diane Poremsky Office for Mac: Insider Fast and Slow Builds Using Outlook 0
M Very slow operation Using Outlook 0
R Slow character rendering after Hebrew used Using Outlook 1
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
B very slow attachments Using Outlook 5
T Outlook 2010 Very Slow To Open Recently Using Outlook 9
Sarge USMC troubleshooting slow startup Using Outlook 6
I Outlook 03 slow startup Using Outlook 5
B Outlook suddenly very slow Using Outlook 4
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
B Outlook 2013 slow or no receipt of emails Using Outlook 0
D Outlook 2000 slow Using Outlook 2
P Oulook 2010 very slow Using Outlook 2
B Slow to receive emails on Outlook 2013 Using Outlook 35
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
B Outlook 2007 - Slow opening folders when inserting attachments Using Outlook 2
A Outlook 2010 slow with Yahoo IMAP Using Outlook 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D Outlook 2010, super slow! IMAP issue I think Using Outlook 1
M bcm painfully slow BCM (Business Contact Manager) 1
C Outlook 2003 very slow to open Using Outlook 5
G Forms error on iCloud calendar Using Outlook 17
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
