bcm painfully slow
mp
Is there any standard tricks to speed up bcm?
link email to project takes inordinate amount of time.
thanks
mark
Dana Stevenson
I am also trying to speed up BCM, just loading it takes a while now. Please
any help would be appreciated.
SBS 2003 hosting BCM Database
2003 R2 TS clients / 20 -25 each server / Server performance looks good
Just slow BCM.
Thanks in advance
Dana
> thanks
> mark
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
