Autocomplete not working
useful
I imported my Contacts into Outlook using a CSV file and all my Contacts are successfully in Outlook.
All my Contacts are also in the Autocomplete cache, because although it was empty to start with, I added all entries using 'Add from Address Book' using Nk2Edit.
The problem is that when I try and use Autocomplete in an email, only some of the Contacts appear and most don't.
I have renamed the Autocomplete cache to OLD, emptied the cache and removed the checkmark on Autocomplete in Outlook, then emailed someone and tested that the Autocomplete function worked and it did. Using Nk2Edit, I then merged the OLD cache with the cache that had the working email address and it still behaved the same way ... only some of the Contacts appear in Autocomplete, regardless of everyone being in the cache.
I have run ScanPST twice, all to no avail although it confirms that the repair completed.
I have run out of ideas,. so if anyone can think of anything to fix this, I would be delighted.
Thanks in advance.
useful
Thanks for your response, but I started with a fresh Autocomplete cache with a known working single email address in it and merged that with the cache that had all of my Contacts.
My problem is that although all my Contacts are now in the Autocomplete cache, only some of them appear when I try to use Autocomplete.
The mystery is that no matter how many times I repeat this process, it is always the same few Contacts that appear when I try to use Autocomplete, even when I start again and populate the cache from the Address Book with Nk2Edit.
Right. But what you've got now, from the steps you've referenced having done already, admittedly isn't working for you.
The "blow-them-out" and the "repopulate" steps at the link above should be quick and painless; and having started with a clean slate...
Say that performing those two steps do not produce the results you're seeking -- Restoring a backup/renamed copy or Redoing the merge with Nk2Edit should be quick and painless and have you back where you are now.
Your last phrase is spot on ... having done what you have suggested a number of times now, I am back precisely 'where I am now'.
Unfortunately, this is not the solution to the problem. I wish it was.
V Autocomplete not working on new email account Using Outlook 4
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
G Autocomplete adds suspicious "@unknown.email" to selected contacts Using Outlook 1
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M email autocomplete broke.. Using Outlook 5
C Autocomplete losing some (not all) addresses Using Outlook 6
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
V Outlook 2013 - transfer autocomplete data Using Outlook 4
A Autocomplete issue Using Outlook 6
Michael Durthaler Outlook 2013 Autocomplete File Is Infected Using Outlook 1
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
G Outlook 2013 AutoComplete Limit Using Outlook 3
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
J autocomplete in "To" field does not work for display names Using Outlook 8
U Imported contacts to appear in Autocomplete Using Outlook 1
V Outlook 2010 Autocomplete Using Outlook 7
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Help with random numbers in autocomplete emails Exchange Server Administration 3
K Autocomplete list not saving distribution list Using Outlook 3
T Autocomplete, although enabled, does not complete names in TO: Using Outlook 4
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
Commodore Automatic switch between working offline/online Using Outlook 4
