Emails fetching into Excel and auto generating Dashboard
How to solve the load and memory issues in VBA?
  • Total voters
    1
santosh v yadav
Exchange Server 2010
I have created the functionality to fetch emails from outlook to ms excel (2010). But when I select 1000 emails and try to fetch to excel from outlook it not fetching the data properly and restarting the outlook.
Here is VBA code:
Sub D2DAcronis() '(MyMail As MailItem)
Dim item As MailItem, x%
Dim r As Object 'As Word.Range
Dim doc As Object 'As Word.Document
Dim xlApp As Object, wkb As Object
Set wkb = xlApp.Workbooks.Open("D:\Backupreport\ServerBackupDasboard.xlsb")
xlApp.Visible = True
Dim wks As Object
Set wks = wkb.Sheets("Data-D2D_Acronis")
wks.Select
Dim rNum As Integer
For Each item In Application.ActiveExplorer.Selection
Set doc = item.GetInspector.WordEditor
wks.Cells(wks.Rows.Count, 1).End(3).Offset(1).Value = item.Body
wks.Cells(wks.Rows.Count, 2).End(3).Offset(1).Value = item.Subject
wks.Cells(wks.Rows.Count, 3).End(3).Offset(1).Value = item.ReceivedTime
wkb.Sheets("Data-D2D_Acronis").Range("A:C").Select
With Selection
.HorizontalAlignment = xlGeneral
.VerticalAlignment = xlCenter
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
Set doc = Nothing
wkb.Sheets("CoverPage").Select
wkb.Save
MsgBox "Successfully imported messages to Excel"
Why are you using word? You can get the subject, body, and time without using word.
plus, you are setting it 1000 times in the loop
either set it before the loop or kill it before the next message.
I guess it's not the entire code else it makes no sense to retrieve the Word.Document.
Also, use a variable for the Selection object instead of calling Application.ActiveExplorer.Selection a thousand times. The same for all of the other references.
I'm not an Excel expert, but wouldn't it be much more faster if you format the entire columns once after all the data is exported instead of doing it per email?
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Action based on number of emails after sort by from Using Outlook 3
D Can't read some emails - text size too small. Using Outlook 2
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
T Outlook is categorizing emails incorrectly Using Outlook 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 20
A Flagged Emails highlighted in yellow Using Outlook 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
J gmail and deleted emails. Using Outlook 0
U Outlook not responding when trying to print Emails Using Outlook 6
K mark emails with colour manually (like in thunderbird) Using Outlook 1
U Outlook on the iPhone cannot approve filtered Emails Using Outlook 0
B Move emails from one account to another Outlook VBA and Custom Forms 2
D Unable to view older emails in desktop app Using Outlook 0
J Outlook 365 Emails showing as links and text only Using Outlook 4
G Removing old emails when adding accounts Using Outlook 3
Horsepower Lost emails Using Outlook 4
