Using DistListItem.AddMember for existing DL
Thomas Hill
Outlook 2013 64 bit
I want to add a new contact to the appropriate DLs at the same time I add the contact. I have the form design, but I'm missing a couple of processes. The main one is how to add the contact to existing DL(s). I have viewed several sites so far, including MSDN, to find how to do this. Every example I've seen so far creates a new list and adds one or more contacts to it.
That would depend on the person being added. For example, Fred Williams, new Admin to the CEO would need to be added to BroadcastAE and Admins. Sally Adams, new IHP Nurse, would need to be added to BroadcastNZ and IHP.
T Using Exchange, the calendar cannot be synchronized. Using Outlook 3
