HOw to keep Outlook iCloud add-in enabled
Mark Klaassen
Outlook 2013 64 bit
Can anyone assist me with this issue, please?
My "icloud outlook add-in" enables until I close outlook, but when I manually reload it, it has error message:
"Apply DAV logging Enabled. This slows down outlook significantly. to disable logging delete the \ZppleDAVLog directory"
I dont understand this. can you please advise what to do, so I can keep the add-in enabled?
Mark
Type or paste %appdata%\apple computer in the address bar of windows explorer and press enter - this will open the folder where the iCloud files should see. See if you can find that log and delete it.
Thanks Dianne, did that, and there are various logs within the directory, but I have no idea what I'm looking for. nor why deleting a log will fix the problem of the app disabling itself.
i don't know why it would help either - but if that is what the warning said...
i don't see the log file in the message in my install (as either Zpple or Apple :))
Is the the exact error message? I'll get you the instructions for forcing it to load in the registry.
Thanks. I'm not very familiar with these things, so I'd be grateful for a simple steps reply that I can follow. dont want to delet anything important cos I misunderstood. cheers
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
D How to keep Outlook 7 open to full screen Using Outlook 2
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
T Why is every new email pinned (to keep it on top)? Windows 10 Using Outlook 6
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
S How do I keep my old PST file as default Exchange Server Administration 1
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
A How to keep all conversations expanded? Using Outlook 3
S Deleted messages keep coming back Using Outlook 7
A Keep format of message in the body Outlook VBA and Custom Forms 1
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
R keep track of the original sender Outlook VBA and Custom Forms 3
L new outlook contacts searching Using Outlook 2
