Outlook rule, specific words, not specific words
Frank Stein
Is there a way to setup a rule for any subject with a specific phrase (like red dog) but ALSO without a specific word (like tree).
so: red dog fire hydrant
would be a trigger, but
red dog tree
would not be a trigger.
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
R Rogue Outlook Rule ? Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
I outlook rule keywords based on list Using Outlook 0
M Outlook 2016 Desktop - Automatic Rule Processing Using Outlook 3
I Create custom Outlook 2013 Rule in Office 365 Outlook VBA and Custom Forms 5
K Outlook moves sender's mail, but there is no rule Using Outlook 0
J Outlook creating unwanted rule on its own Using Outlook 1
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
Gary Brown Outlook 2013 VBA to run a rule Outlook VBA and Custom Forms 13
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
G Creating an Outlook Rule using Internet Header time Using Outlook 1
N rule to move sent mail to the deleted folder in outlook Using Outlook 4
M Outlook Rule To Redirect Mail - Script to overcome lack of cc's & others Using Outlook 0
J outlook rule doesn't run automatically Using Outlook 0
K Implementing an AND logic rule in OUTLOOK Using Outlook 1
C Outlook rule moves e-mail to a deleted folder Using Outlook 1
E Outlook rule only active certain times of day Using Outlook 6
W Outlook sent to "person" rule excluding cc Using Outlook 2
D Private messages not forwarding by rule? Outlook 2007 Using Outlook 1
F Outlook Rule using message header not working Using Outlook 2
M Outlook 2003 rule to detect a blank category Using Outlook 1
J Create or Import a Outlook Rule through C# code. Outlook VBA and Custom Forms 2
G Outlook rule check for messages not received Outlook VBA and Custom Forms 2
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How to create hidden rule in outlook 2007 Outlook VBA and Custom Forms 3
T forcing a rule when opening outlook via code Outlook VBA and Custom Forms 1
N Outlook alert/memo/rule when an email does not arrive Using Outlook 3
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
K Re: Cuestom outlook rule using vba Outlook VBA and Custom Forms 4
