Restoring PST files won't work
Brassrng
Hi all;
I'm hoping for a magic bullet, or an idea that may work.
I have 3 .pst files from an archiving effort some months ago.
They will not restore, I can't open or view them.
When making attempts to access them, Outlook 2003 crashes every time.
I ran a repair on the pst files, they are supposedly good files.
Is there any other way to gain access, even opening or converting to a text or database file in order to extract the main details I still need?
Thanks for any ideas
jim
B Restoring deleted pst file Using Outlook 1
L Restoring Outlook from backup of OST Using Outlook 5
P Restoring old sbb database in existing one BCM (Business Contact Manager) 4
D Outlook 2010/IMAP - Restoring from system tray changes to unused ibox.... Using Outlook 1
N Restoring Outlook Calendar after iCloud copy Using Outlook 1
B Restoring Deleted Recurring Event AND Notes Using Outlook 8
G Restoring emails Using Outlook 4
S Restoring Database to BCM BCM (Business Contact Manager) 2
A BCM 2007 restoring database BCM (Business Contact Manager) 1
P Restoring bcm BCM (Business Contact Manager) 4
S Restoring BCM from a Back-up BCM (Business Contact Manager) 3
KuldeepTech How Do I Extract All Emails from a PST File? Using Outlook 1
K I built an open-source, offline OST to PST converter for Windows Using Outlook 9
S PST Reader App Using Outlook 0
S Thank you Diane, Plus pst files question Using Outlook 8
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
B MMF to PST converter Using Outlook 1
S Indexing PST Files Using Outlook 0
S Organizing a .Pst Outlook VBA and Custom Forms 0
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
T Cannot open .pst file Using Outlook 2
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
B How to get PST folder datetime? Outlook VBA and Custom Forms 1
P Recommendation for PST repair program Using Outlook 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J Recover server side rules from OST/PST without access to the server Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
L Article on merging pst file Using Outlook 1
