using macro to send attachments
Omar
I am using macro to send reports saved in c:\Reports and then move the files to c:\Complete once its send out.
I was wondering if there is a way to auto run the macro if report files become available at C:\Reports folder. Or a macro code that can watch C:\Reports folder and then call the macro SendFilesEmail(). Thanks again.
I am using outlook 2010, win 7
I don't have any code samples that watch windows folders but I'm sure it's possible.... cloud sync software watches the folder and there are at least 2 utilities that do this. You'll need to use windows api to do it.
H send reminder if no reply received on first or original email using macro Using Outlook 2
T Using a macro to send email to diffrent address Outlook VBA and Custom Forms 1
Diane Poremsky Embed Images in New Messages using a Macro Using Outlook 0
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
reza Macro to automatic reply using orignal mail Outlook VBA and Custom Forms 10
nathandavies How to save emails to a specific folder on a network automatically using a macro Outlook VBA and Custom Forms 14
B Auto reply using macro include original email Using Outlook 4
J Macro generating email using default signature and hyperlink Outlook VBA and Custom Forms 5
M Reply Macro using O365 Connected Account Using Outlook 2
H using macro for sending multiple mail in outlook Outlook VBA and Custom Forms 1
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
R Trigger Application_ItemSend event when sending using Access macro Outlook VBA and Custom Forms 2
