Change devider and send hyberlink with informations.
stonefox
My plans are to change Email providers, and when my current mail will be deleted, I have a wish to in good time to inform my contacts that my mail is will be changed.
1. Is it possible for Outlook 2013 to change my current sender mail, to the new, so recipients automatically reply back to my new address and the new provider's mail server?
2.
Can I in the mails I send make a hyberlink or anything else that makes it possible for the receiver to activate and thus be asked whether he will store this information in their mail program?
Thinking about the same function as when sending a text message to the recipient with a link on all your personal contact information, ready to be activated and stored on the recipient's phone.
W frustrating trying to change email password Using Outlook 5
R Outlook 2021 change view Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
Horsepower Contact phone numbers randomly change Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
whizzard Change FROM address based on TO or CC address Outlook VBA and Custom Forms 8
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 90
P How can I change my calendar view back Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
W Appointment occurrences change the location property Using Outlook 0
