Quick Parts signatures suddenly require more letters
Cara
Outlook 2021 64 bit
I use quick parts to insert audience-appropriate signatures (internal, external, casual) to my outgoing emails.
I preface the quick part names with sig:, so I have sig:Inside, sig:Outside, sig:Casual.
We had a "rebranding" here that required me to change my external and internal signatures. I edited the existing quick parts, no problem (don't honestly remember if I edited or saved over them with the same name).
Now, however, rather than entering sig:in and hitting F3 to get the signature to appear, I have to enter the FULL quick part name before it's recognized.
Any idea what could cause this? I've double-checked the list of my quick parts, and there are no similarly-named ones.
Either you have two quick parts with the same name or outlook thinks you do - as soon as you get to a unique quick parts, F3 (or Enter) should be enough to complete it. Try deleting or renaming the email template at %AppData%\Microsoft\Templates and recreate the quick parts
Is there a reason you use quick parts instead of the signature function? You can either insert a default signature then right click and choose a different one or use the insert sig command.
M font format discrepancies with Quick Parts Using Outlook 1
B Push Quick Parts to All Users Using Outlook 1
D Quick Parts - font changes Using Outlook 6
D Quick Parts - font changes Using Outlook 0
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
S Quick Parts - Changing Display and Order Using Outlook 0
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
A Quick Access Toolbar Not Showing Description Using Outlook 0
J Text icon in Quick Access toolbar ? Using Outlook 2
Ken Pascoe Outlook Categories Quick List Using Outlook 0
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? Using Outlook 0
S Save in folder other than Sent when replying with Quick Steps Using Outlook 5
R Missing Quick Steps and Rules Using Outlook 0
A Quick Steps in Tasks view Using Outlook 7
J quick quesiton about outlook search Using Outlook 3
iwshim Skype tool bar in quick access ribon Using Outlook 1
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
L Quick step to fill custom field Outlook VBA and Custom Forms 1
adaminaus Quick question if i may Using Outlook 4
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
L Outlook Data Files command not working in the quick access bar Using Outlook 1
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
B quick help with "changed by" field in a shared mailbox?? Using Outlook 3
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
S Quick Search will not work due to itemizing Using Outlook 1
E Blank Print Preview when access via the Quick Access toolbar Using Outlook 3
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
K Quick Print shows wrong date on Occurrences Using Outlook 1
I Office 2010 Quick Steps Using Outlook 10
T Quick Access Toolbar Using Outlook 3
S Quick access toolbar in inspector window Outlook VBA and Custom Forms 3
V Parts of Outlook UI transparent Using Outlook 2
