Saving emails using Visual Basic - Selecting folder with msoFileDialogFolderPicker
mail11
Hi, I asked this a few years ago but didn't get a response.
Was hoping it's now possible.
This macro saves selected emails into a folder chosen by function "BrowseForFolder". It also adds the date as part of the filename. My issue is that the default start folder selected is always the same and I have to navigate to the folder each time.
I want to use "msoFileDialogFolderPicker" to select the folder because this is able to remember the last folder chosen and default to that path as the start when the macro is called again.
msoFileDialogFolderPicker can be used in Excel.
Option Explicit
Public Sub Save_Messages_Select_Ask2()
Dim oMail As Outlook.MailItem
Dim objItem As Object
Dim sPath As String
Dim dtDate As Date
Dim sName As String
Dim enviro As String
For Each objItem In ActiveExplorer.Selection
If objItem.MessageClass = "IPM.Note" Then
Set oMail = objItem
sName = oMail.Subject
dtDate = oMail.ReceivedTime
sName = Format(dtDate, "yyyy mm dd", vbUseSystemDayOfWeek, _
vbUseSystem) & Format(dtDate, " hhnn", _
vbUseSystemDayOfWeek, vbUseSystem) & " - " & sName & ".msg"
sPath = BrowseForFolder(enviro & "\Documents\")
Debug.Print sPath & "\" & sName
oMail.SaveAs sPath & "\" & sName, olMSG
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
Dim ShellApp As Object
Set ShellApp = CreateObject("Shell.Application"). _
BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
BrowseForFolder = ShellApp.self.Path
On Error GoTo 0
Set ShellApp = Nothing
Select Case Mid(BrowseForFolder, 2, 1)
Case Is = ":"
If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
Case Is = "\"
If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
Case Else
GoTo Invalid
Exit Function
Invalid:
BrowseForFolder = False
End Function
I have a sample that uses Word's object model to access msoFileDialogFolderPicker here -
The VBA code is basically the same as you would use in Word or Excel - you just need to reference the app's object model so outlook can access it. Some (or most) but not all macros recorded in either of those apps can be used in Outlook if you reference the object model. In some cases you will need to use early binding though.
Hi, thanks but I couldn't see anything in that link relating to msoFileDialogFolderPicker.
With the simpler one above, there is a variable called OpenAt. Is there a way to specify this and store the value for next use?
From the macro the link points to -
    'Set the dialog box type to Open
    Set dlgOpen = wdApp.FileDialog(msoFileDialogFilePicker)
This sample uses a specified folder path to start - but you can only browse subfolders, not go up a level.
The values are:
BrowseForFolder(WINDOW_HANDLE, "Window Title", WINDOW_OPTIONS, StartPath)
In the function it is
the path is passed as the value of openat:
StrFolderPath = BrowseForFolder("C:\Users\diane\Documents\Email\")
If I use the variable option so it works on any computer:
StrFolderPath = BrowseForFolder(StrUserPath)
I need to dim StrUserPath as a variant, not a string, so it jumps to the right folder. If it's a string, it goes to the user's home folder. (I will fix that in my code)
Dim StrUserPath As Variant
Or I can do it this way:
OpenAt = StrUserPath
' Get the BrowseForFolder function How to use Windows filepaths in a macro
StrFolderPath = BrowseForFolder(OpenAt )
And my example path is not going to let me browse, because it only browses down -
Use the topmost folder so you can browse subfolders-
OK thanks, this is useful, but it's a shame there's no ability to go up a level.
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
Kevin H Remotely saving emails Using Outlook 1
D Saving outlook emails in html and attachments Using Outlook 4
C Saving Emails as Messages Problems with Access Data Collection et Outlook VBA and Custom Forms 1
S Automate saving of attachments on new incoming emails Outlook VBA and Custom Forms 3
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
CWM330 Saving Data: Don't check certain folders Using Outlook 2
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
B Saving items under a folder Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
T Saving all email to file folder in Windows Using Outlook 2
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
D Remove extension while saving attachments Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
S Not saving attachments in the Sent Folder Using Outlook 2
W Default Saving a message as text Using Outlook 2
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
