Outlook 365 Help me create a Macro to make some received emails into tasks?
sami52226
Outlook 365 32 bit
Hello, because I often miss all of the tasks I have to do I wanted to automate some things in outlook.
Every time I have to do something new I get an email in a standardized form. I would like to have a macro that automatically takes the Mail with a specific subject, copies a specific part of text (that is always in the same place) makes this the title of the task and sets the start date, the date of receiving the email and the due date to one week from receiving the email. Also nice would be that the email is attached to the task.
At the moment in the email is also a Due Date, but this is not working at the moment so there is written none at the time, but in the future it will work, and it would be nice to have the due date automatically set to the due date in the mail.
I hope someone can help me.
BR
Samuel
May not be exactly what you are looking for but this should get you started. I pulled the bulk of this code from a post Diane made a while ago:
Sub ConvertEmailToTask()
''''Original Code From:
''''Create Task or Appointment and Insert Selected Text
'You need the GetCurrentItem Function from: Outlook VBA: Work with Open Item or Selected Item
Dim objTask As Outlook.TaskItem
Dim oItem As Object
' Add reference to Word library in VBA Editor, Tools, References
Dim objInsp As Inspector
Dim objDoc As Word.Document
Dim objSel As Word.Selection
''''Dim NewMC As
Set objMail = GetCurrentItem()
Set objTask = Application.CreateItem(olTaskItem)
If objTask.MessageClass <> "IPM.Task.GTD Task" Then
objTask.MessageClass = "IPM.Task.GTD Task"
CopyAttachments objMail, objTask
If Not objMail Is Nothing Then
If objMail.Class = olMail Then
Set objInsp = objMail.GetInspector
With objSel
'use wholestory to copy the entire message body
.WholeStory
.Copy
Set objInsp = objTask.GetInspector
Set objSel = objDoc.Windows(1).Selection
''''''''''''''''''''''CopyAttachments oItem, oTask
With objTask
'.MessageClass = "IPM.Task.GTD Task"
.Subject = objMail.Subject
'.DueDate = objMail.ReceivedTime + 3
'.StartDate = objMail.ReceivedTime + 2
objSel.PasteAndFormat (wdFormatOriginalFormatting)
'.Categories = "From Email"
' .Save
.Display
'objMail.Categories = "Task" & objMail.Categories
Set objTask = Nothing
Set objMail = Nothing
Set objSel = Nothing
Set objInsp = Nothing
Set objWord = Nothing
Sub CopyAttachments(objSourceItem, objTargetItem)
Dim fso As Object
Dim fldTemp As Object
Dim strPath As String
Dim objAtt As Attachment
Dim strFile As String
Set fso = CreateObject("Scripting.FileSystemObject")
Set fldTemp = fso.GetSpecialFolder(2) ' TemporaryFolder
strPath = fldTemp.Path & "\"
For Each objAtt In objSourceItem.Attachments
strFile = strPath & objAtt.FileName
objAtt.SaveAsFile strFile
objTargetItem.Attachments.Add strFile, , , objAtt.DisplayName
fso.DeleteFile strFile
Set fldTemp = Nothing
Set fso = Nothing
P Please Help me Create a Macro ! Using Outlook 2
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
D Request help with a macro for forwarding email Outlook VBA and Custom Forms 5
