How to simplify rules
runninglate
Outlook 365 64 bit
I have used Outlook for many years and many versions, and use rules to move incoming emails to topical folders, and copy outgoing email to the topical folders. I now have 117 rules which seems like too many. I am trying to consolidate them, but many of the were created from the outlook email pane by right clicking on the email, choosing rules, then "always move..." which works fine but winds up establishing a separate rule for every email address. As an example, I have multiple rules from emails with the from Display Name "American Airlines", but I would like all of them in a single folder. I'd like to use one rule to move all emails from various AA addresses to the proper folder. Adding a rule this way from the email pane does not add the email address to my contacts or address book, but seems to put it in Rule Addresses and when I examine the rule and click on the Display Name e.g. "American Airlines" I get a menu labeled "Email Properties" which shows the email address. To consolidate two AA rules into one I wind up creating an address with the Display name "American Airlines" and the email address, then going into rules and adding this to my existing rule. I need to be cautious because sometimes email addresses don't clue you in on the Display Name and make sure I add the Displauy As (email address) Display Name e.g. no-reply@info.email.aa.com(AA2)'
Is there a simpler way to combine existing rules? Is there a best practive limit on the number of rules to use?
Switch to the Simplified View.
To switch back and forth between the Simplified Ribbon and the classic ribbon, click the downward pointing caret in the lower right corner of the full, classic ribbon to collapse it to the Simplified Ribbon. The Simplified Ribbon shows your most used commands in a single line.
Or better yet, is there a third-party tool (or utility) to edit Outlook rules outside of Outlook itself. Within Outlook, rules creation and editing is quite cumbersome.
J Recover server side rules from OST/PST without access to the server Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Setting rules Using Outlook 1
A rules not working Using Outlook 2
M Rules and autoreply Using Outlook 1
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
L Office 365 cloud based rules Using Outlook 1
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
R When rules lose track of "specified folder" Using Outlook 6
I Outlook 2013 Rules - (client only) Using Outlook.com accounts in Outlook 1
A rules (flags) not working Using Outlook 7
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
R When rules are working but invisible and unmanageable Using Outlook 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
D Outlook Rules Using Outlook 1
Diane Poremsky Autoaccept a Meeting Request using Rules Using Outlook 2
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
P Log of Rules that ran Outlook VBA and Custom Forms 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
T Client-side rules not working, but no error Using Outlook 1
