Categories Not Saved
  • Thread starter Thread starter spottedmahn
It looks like there was a bug and it was fixed by a June roll-up that I had
installed, so I didn't see your problem. Download the roll-up from
http://support.microsoft.com/kb/970944 and see if that fixes your problem.
"spottedmahn" <spottedmahn> wrote in message
news:6AD5325B-9995-4719-9AD2-BE4E9E173A7C@microsoft.com...
> Thanks for all of your input Ken.
> I'll open a case with MSFT and post the results.
> Regards,
> Mike D.
Hi Ken,
Thanks for the post.
I was able to obtain the Hot Fix but unfortunately it did not resolve my
problem. I have a support case open and the rep, Brij, provided me with a
workaround that appears to be working.
By removing the category and then readding it the changes are saved.
Namespace.Categories.Remove(Name of Category)
> > Regards,
> > Mike D.
Hi Ken,
I am using C++ with MAPI to communicate with outlook.
Can you suggest me a way to retrieve/add/delete the categories from master
categories list.
I am able to retrieve category name for a contact but how to retrieve it's
color and shortcut keys. I am using outlook 2007
S Folder Pane Colour Categories Using Outlook 6
Ken Pascoe Outlook Categories Quick List Using Outlook 0
O Calendar - appointment templates and categories Using Outlook 1
T Increasing the number of items that appear on the Categories list Using Outlook 2
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
Z How to show concatenated categories in list task view? Using Outlook 2
A Outlook reverse categories Outlook VBA and Custom Forms 1
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
P Task Categories Using Outlook 2
I categories for outgoing email Outlook VBA and Custom Forms 7
S Appointment colour categories disappear Using Outlook 4
Z Outlook.com Contact categories Using Outlook 8
Diane Poremsky Using Categories for Dynamic Distribution Lists Using Outlook 0
avant-guvnor Outlook 2016 and views, categories etc. Using Outlook 3
T categories in Outlook 2016 Using Outlook 0
makinmyway How to Easily/Quickly Ungroup by Categories Using Outlook 1
C Printing tasks with multiple categories Using Outlook 5
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Outlook 2007 adding categories Using Outlook 15
E Outlook 2013 is stripping out categories on sent meeting invites Using Outlook 0
Karlski Deselecting categories often takes 3+ attempts Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
K Missing Categories & Colors Using Outlook 5
V Outlook 2010 – Send email based on categories Using Outlook 2
W Sync categories between Exchange and 2007 Exchange Server Administration 1
C Adding Categories when Composing Email Using Outlook 1
D Error in the Categories view Using Outlook 2
J Lost email categories when migrating from Office 2010 to Office 2013 Using Outlook 3
Semipro50 CATEGORIES Using Outlook 4
B Outlook 2013 categories Using Outlook 1
