What is it, and why won't it load?
  • Thread starter Thread starter petermat
P
petermat
I have just sucessfully installed disc 1 of Office Pro 2007 (onto XP SP3 +
latest updates) and updated it - SP2 etc., etc..
Disk 2 howevever will not load - I get -
"CD 2 for the Business Contact Manager failed to install - log files
available. I tried this right after CD 1 finished and again after getting a
full set of updates for windows and office. Same failure in both cases -
Business Contact Manager for Outlook 2007
Setup failed to install the required component Microsoft SQL Server 2005
Express (MSSMLBIZ). Business Contact Manager for Outlook 2007 cannot
continue. See C:\Program Files\Microsoft SQL Server\90\Setup
Bootstrap\LOG\Summary.txt for more detail.
OK
Before diving into posible solutions to this, can anyone explain what BCM
actually does in concrete specific terms? I did not buy Pro for this, and I
have no idea what it does - but I do run my own business. It may be I don't
want what it does, in which case working to install it could be a waste of
time - though it's anoying to buy something and have it not work!
petermat
http://office.microsoft.com/en-us/contactmanager/HA101656361033.aspx
"petermat" <petermat> wrote in message
news:5BEE930E-477D-498B-85EA-A235F39DEF27@microsoft.com...
> a
> "-------------------------> Business Contact Manager for Outlook 2007
> -------------------------> Setup failed to install the required component Microsoft SQL Server 2005
> -------------------------> OK
> I
> don't
> > petermat
OK, thanks DL, that's the first thing (sorry my searches did not turn that up).
It looks like BCM could be useful to me, so now there is the second part -
how can I get around the 'won't install' problem? I tried installing straight
after Disc 1 loaded, also after updating basic Office to SP2, also after
updating everything MS offered. Same results in all cases.
petermat
> > a
> > "-------------------------> > Business Contact Manager for Outlook 2007
> > -------------------------> > Setup failed to install the required component Microsoft SQL Server 2005
> > -------------------------> > OK
> > I
> > don't
> > > > petermat
So what does the log txt file say?
news:42ABA0BC-993F-4D8E-8798-7ED729BB8CA8@microsoft.com...
> up).
> straight
> > petermat
> > > getting
> > > a
> > > cases -
> > > "-------------------------> > > Business Contact Manager for Outlook 2007
> > > -------------------------> > > Setup failed to install the required component Microsoft SQL Server
> > > 2005
> > > -------------------------> > > OK
> > > BCM
> > > and
> > > I
> > > don't
> > > of
> > > > > > petermat
I have the same problem; installed disk 1 ok, but disk 2 will not install,
said the microsoft office 2007 primary interop assemblies could not load. I
went to Microsoft, downloaded their interop assemblies; still nothing.
> > petermat
I too am having the same problem. Running Windows 7 Professional 64-bit.
Here's detail of attempted install. Disk 1 of Office Small Business 2007
installed without a problem, but Disk 2 with Business Contact Manager and SQL
Express (default install, no choice) will not install. The Setup Wizard
screen just continues to show the installation in progress screen as the
"green" install line tracks gradually across to complete but then it just
repeats inself. After several aborted attempts I let this continue overnight
and it was still running same loop. A Known Program Compatibility Assistant
screen does appear that has button to check for solutions online that comes
back with the message that no solutions are available. There is also a
notice to apply SQL Server 2005 Pack 3 before you run SQL Server 2005 (which
of course can't be done since it never installs). Could not find solution
via support search. Only reason purchased Small Biz version of Office instaed
of cheaper version was for Business Contact Manager. Please help if you can.
> > > > petermat
Did you have any joy resolving this, I'm having exactly the same problem.
Rob
> Thanks.
> > > -------------------------> > > Setup failed to install the required component Microsoft SQL Server 2005
> > > > > > petermat
Same Here!
I used the CRM Outlook Add-In Avidian Prophet for the past two years with
Outlook 2007 on WinXP but ran into difficulties when I installed Windows 7.
So I tested Outlook 2007 with BCM on a laptop still running XP, decided that
it would be a usable replacement for Prophet but can't install in on my
Windows 7 office computer. Keep getting the "Failed to install the required
component Microsoft Office 2007 Primary Interop Assemblies message. Since the
control panel claims that it is installed, I was about to attempt an
uninstall-reinstall of Office 2007, but the other postings here don't give be
confidence that that would work. Has anyone found a solution? Does anyone
know how we can get Microsoft to address this? Unbelievable!
> > > > petermat
I also am experiencing this issue. Any results would be helpful.
Jeff
"Sandcarver" wrote:
> Same Here!
> > > > > > petermat
I found this possible solution in Microsoft's Troubleshooting section of
Office Online for Outlook with Business Contact Manager. Solutions are shown
for XP and Vista, but this might also work for Windows 7.
Q. I received a message stating that Business Contact Manager for Outlook
installation did not complete because the Primary Interop Assemblies program
must be installed.
A. In some instances, you may find that the Microsoft Office Primary Interop
Assemblies program is already installed. In this case, remove the Primary
Interop Assemblies program, and then try installing Business Contact Manager
for Outlook again.
ShowWindows XP
1. On the Start menu, click Control Panel.
2. In Control Panel, click Add or Remove Programs, and then click Remove
a program.
3. In the Currently installed programs list, click Microsoft Primary
Interop Assemblies, and then click Remove.
4. Follow the instructions on your screen.
HideWindows Vista
2. In Control Panel, under Programs, click Uninstall a program.
3. Click Microsoft Primary Interop Assemblies, and then click Uninstall.
> Thanks,
> Jeff
> "Sandcarver" wrote:
> > Same Here!
> > > > "-------------------------> > > > Business Contact Manager for Outlook 2007
> > > > -------------------------> > > > Setup failed to install the required component Microsoft SQL Server 2005
> > > > -------------------------> > > > OK
> > > > > > > > petermat
I installed disc 1 of Office Pro 2007 (onto XP SP3 +
latest updates).
Disk 2 however will not load - I get -
John Bakas
Riverview, Florida, USA
J add-in won't load Outlook VBA and Custom Forms 12
Rupert Dragwater Mail won't show as read Using Outlook 2
icacream New password won't update Using Outlook 2
C Why won't Title display in message list? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
M outlook won't open! Using Outlook 1
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
M other user's mailbox won't open, forms disappeared Using Outlook 42
P Outlook 2016 won't Start Using Outlook 3
Phil52 Outlook won't work Using Outlook 1
N editing drafts - won't let me save Using Outlook 12
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
Jaegel Email Hyperlinks from one source won't open Using Outlook 4
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
A iPhone Contacts in Outlook won't File As First, Last Using Outlook 0
JulieB Default data file won't change Using Outlook 6
B Restoring PST files won't work Using Outlook 1
J Outlook won't open. PST file busy. Using Outlook 3
P Outlook 2007 won't connect Using Outlook 6
S Outlook 2010 won't send on Windows 8 Using Outlook 2
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
K Macro won't consistently re-enable Outlook VBA and Custom Forms 2
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
V Custom form won't open for edit Outlook VBA and Custom Forms 3
C images won't display in email Using Outlook 2
J why won't the automatic send/receive work Using Outlook 7
B icloud calendar stopped syncing, won't restart Using Outlook 1
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
R Emails won't come into outlook but can send Using Outlook 0
G Why won't VBA see a copied calendar in cache mode anymore? Outlook VBA and Custom Forms 20
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
Z Outlook opens minimized, won't maximize Using Outlook 2
J Email won't send Automatically in Outlook 2010 Using Outlook 3
G Outlook 2013 won't download images Using Outlook 6
O Calender first day Sunday won't stay Using Outlook 3
