Using a PropertyAccessor custom datetime property in Views
  • Thread starter Thread starter wclarke101
W
wclarke101
I'm having problems getting a datetime property (added using
PropertyAccessor) to display as a column in a customised View.
I've added the datetime property to the PropertyAccessor using the following
code...
objMailItem.PropertyAccessor.SetProperty("http://schemas.microsoft.com/mapi/string/{FFF40745-D92F-4C11-9E14-92701F001EB3}/DocumentDate", dtDocumentDate)
> ...where dtDocumentDate is a Date variable.
I've then tried to customise the folder's View to show this custom property
as a column. This is the XML excerpt...
<column
<type>datetime</type
<heading>DocumentDate</heading
<prop>http://schemas.microsoft.com/mapi/string/{FFF40745-D92F-4C11-9E14-92701F001EB3}/DocumentDate</prop
<width>200</width
<style>padding-left:3px;;text-align:left</style
<editable>1</editable
<format>M/d/yyyy||h:mm tt</format
<displayformat>2</displayformat
</column
> ... but the when I run the application, the this DocumentDate column just
displays the word "None".
If i changed the XML to use a string column instead of a datetime column,
then it displays the date, but the column sorting doesn't work properly
because Outlook is treating the values as strings.
How do i reference a custom datetime property in the View XML? Any help
would be greatly appreciated.
I'm using VSTO with Outlook 2007.
Wayne.
http://schemas.microsoft.com/mapi/string. You are creating a PT_STRING8
property, not a PT_SYSTIME property, why would you expect it to correctly
display in the grid as a date/time column?
"wclarke101" <wclarke101> wrote in message
news:0F285D68-DF35-4AC8-98BC-3F2E736F83D5@microsoft.com...
> Hello,
> following
> code...
> dtDocumentDate)
> property
> <column
> <width>200</width
> </column
> Thanks,
> Wayne.
Thanks Ken.
How do I add a PT_SYSTIME custom property to PropertyAccessor that would
then display as a date/time column in the grid?
Do you have sample code for the SetProperty method call and the XML column
tag I would need?
Wayne.
> > Hello,
> > following
> > code...
> > dtDocumentDate)
> > property
> > <column
> > <width>200</width
> > </column
> > Thanks,
> > Wayne.
Why not just use the UserProperties collection?
The http://schemas.microsoft.com/mapi/id/ PropertyAccessor namespace does
take a GUID, but it also requires a property tag. You couldn't refer to the
property by name, since it wouldn't have a name but a property tag.
Unfortunately there is no GetIDsFromNames() method in the object model that
would allow using a name and deriving a MAPI property tag from it.
You would use something like this, given that a PT_SYSTIME has the property
tag OR'd with 0x0040. This example uses an id value picked at random,
0x8502:
Const Custom_Tag =
"http://schemas.microsoft.com/mapi/id/{FFF40745-D92F-4C11-9E14-92701F001EB3}/85020040"
Note that the const should be all on one line as a continuous string. The
GUID is the same as your custom namespace GUID and the id part is composed
of the 0x8502 value I selected at random and the 0x0040 value for a
PT_SYSTIME.
You would use that const with your call to PropertyAccessor.SetProperty()
and in your view XML. That should be the only change needed in the view XML.
news:41BCB1C5-462E-48EF-9070-F2E9619DD24C@microsoft.com...
> Thanks Ken.
> tag I would need?
> Thanks,
> Wayne.
